13w7
Old Sep 25, 2005 | 09:47 PM
fenderlover's Avatar
13w7
could u fit 2 or just 1 jl audio 13w7 in the trunk w/o spare tire kit
Old Sep 25, 2005 | 09:54 PM
lurch519's Avatar
www.evoperform.com
you could probably fit 2 in there, but i dont know where you would put the amps. trunk only has about 7.5 cubic feet of space, and the 13w7 requires 2.085 gross enclosure volume (not including the box material itself) per sub. that means that you only would have about 3 cubic feet of space for amps, and any other stuff (caps, batteries, interconnects, wires, etc). to run each sub, you would want to run a 1000/1 amp per sub, so when all is said and done, you might be able to put a spare quart of oil in the trunk.
Old Sep 25, 2005 | 09:59 PM
lol has anyone else had success with larger subs 12+ in the rx8?
Old Sep 25, 2005 | 10:10 PM
lurch519's Avatar
www.evoperform.com
i hate to say it, but if you are going for spl (which seems very likely to me asking about 13w7 or large subs), either you need to lose the back seat (seen one 8 done like that, ghetto, even though it was a nice install) or get a different car, like an excursion, expedition, suburban, etc. also, i could say stay away from jl, as they have really tried to screw over the customers that made them so popular to begin with.
i work at a specialty retailer, and we have carried jl audio for nearly 10 years, and recently decided to discontinue carrying the line, as they now have only a 90 day warranty for any sales over the counter, vs 1 year for authorized dealer installed.
i feel that they basically gave their customers the big number one salute.
Old Sep 25, 2005 | 11:04 PM
Kel Rx8's Avatar
if your not 1st your last
theres a thread maybe at the bottom with a w7 installed not sure if it was a 13 or a 10'
but I imagine one is all you need.his car is also on cardomain.
Old Sep 26, 2005 | 11:34 AM
rkostolni's Avatar
It would be very difficult to fit two 13w7's. I have a 12w7 and that thing barely fits. I'm not even sure 1 would fit easily height wise. My box is only slightly taller than my 12w7 and it barely fits. I'm not saying its impossible by any means I'm sure it can be done. But I don't think it would be a direct drop in. You could maybe install it at an angle or something. But I have to tell you 1 12w7 is pretty damn loud. I couldn't take it any louder and I don't even push myne that hard.
Old Sep 26, 2005 | 04:26 PM
staticlag's Avatar
The Professor
90days!
JL, you bastards!
Old Sep 26, 2005 | 04:51 PM
lurch519's Avatar
www.evoperform.com
Originally Posted by staticlag
90days!
JL, you bastards!
yup, jl loves the customers.............money that is
Old Sep 26, 2005 | 11:10 PM
but jl's new subs still have the quallity right?
also rkostolni could u upload a pic?
Old Sep 26, 2005 | 11:13 PM
lurch519's Avatar
www.evoperform.com
same quality as before, no real new innovations. just reusing same old technology, bringing out all the "v2" subs. and the whole "w" cone thing on the w7 that they brag about, was actually used around the early 1900's if i remember correctly.
Old Sep 27, 2005 | 01:55 PM
rkostolni's Avatar
There's some pics in this thread.
https://www.rx8club.com/showthread.p...34#post1040034
Old Sep 28, 2005 | 06:25 PM
2 questions rkostolni
1st y didn't u use the box design jl gave for the w7?
2nd y did u use such a big box for 1 sub?
not trying to criticize just to question to further my knowledge
Old Sep 28, 2005 | 07:06 PM
rkostolni's Avatar
Well I didn't use the exact dimensions because they wouldn't fit. It is the recommended 1.375 cu.ft air space though. The outside dimensions are actually slightly larger to account for the air space from the magnet and the internal bracing inside the box. I was careful to get the box very close to the recommended size.
Old Sep 28, 2005 | 09:09 PM
i see, but if u wanted to could u put two?
Old Sep 29, 2005 | 12:01 PM
rkostolni's Avatar
If you wanted to put the drivers in the proper sized box, and keep your back seat it would be very difficult. You definitly would have absolutely zero trunk left. It would require some creative thinking, but probably possible. It would definitly require a FG Box.
Really though, 1 12w-7 is ridiculous. I've never had a system before that I had to turn down because it was too loud, but with my W-7 I often have to turn it down becuase my ears start hurting. And I've had many systems over the years, here's a breakdown for comparison purposes.
2 12" kicker comps
2 12" kicker VR comps
2 12" jlaudio w-4
2 12" jlaudio w-1
None of these were ever as loud as my 1 W-7. And my W-7 is in a sealed box, but it in a ported and I can't begin to imagine how loud it would be. Although I have been considering doing that for a while now, but it would require a fiberglassed box to fit.
Old Sep 29, 2005 | 04:09 PM
fg box?
Old Sep 29, 2005 | 04:17 PM
lurch519's Avatar
www.evoperform.com
fiber glass
Old Sep 29, 2005 | 04:42 PM
how would fiberglass help/be better
Old Sep 29, 2005 | 06:30 PM
rkostolni's Avatar
1. FG doesn't have to be as thick to obtain the same rigidity as MDF so you save space that way.
2. With FG the box can contour to the trunk. With MDF you can only build rectangles so a lot of space is wasted.
Old Sep 29, 2005 | 07:03 PM
mdf?
also what about the box jl audio recomends
Old Sep 29, 2005 | 08:53 PM
Kel Rx8's Avatar
mdf is the wood most commonly used when building boxes.its sold at homedepot
and very cheap
are you looking for a custom box to fit the trunk with a 13w7 in it ?
Old Sep 29, 2005 | 09:05 PM
staticlag's Avatar
The Professor
Originally Posted by fenderlover
mdf?
MDF= Medium Density Fiberboard
Old Sep 29, 2005 | 09:12 PM
staticlag's Avatar
The Professor
Building sub boxes is easy as apple pie. The only thing tricky is that people ususally dont have the right tools. All you need is a tube of liquid nails, a drill, a circular saw, a sheet of 3/4" MDF, and a jigsaw.
Old Sep 29, 2005 | 09:18 PM
lurch519's Avatar
www.evoperform.com
those are tools that can be used to build a box.
the right tools, for a good quality box would be:
MDF
good table saw
wood glue
finish nail gun
hole saw
drill motor
router with circle jig.
Old Sep 29, 2005 | 09:59 PM
ya i am looking for a custom box, and hope to fit 2 13w7's in it
