Amplifier Cooling problem
Old Sep 20, 2005 | 04:59 PM
kirksaeter88's Avatar
It gets really hot in my trunk during the summer and my amp has to shut off a lot to cool down. anyone have any ideas on how to get cool air to my amp? would fans help?
Old Sep 20, 2005 | 08:38 PM
Kel Rx8's Avatar
if your not 1st your last
where are the amps mounted
what type of amps also
Old Sep 20, 2005 | 09:28 PM
forbidden's Avatar
Ensure that it is grounded properly with a low return resistance as well. Resistance manifests itself as heat in an amplifier. Read the grounding sticky at the top of the forum.
Old Sep 21, 2005 | 07:13 AM
ayrton012's Avatar
Ayrton Senna Forever
open the slot between the rear seats, so the cooled air (by Aircond) can get into the luggage place, or if you dont use the rear speaker take out those. If its still not enough place a vent to the holes of the speakers! (or buy a vented amp. )
Old Sep 21, 2005 | 03:32 PM
it is a Phoenix Gold Titanium 600.2 mounted on the floor of the trunk.
Old Sep 21, 2005 | 04:56 PM
Kel Rx8's Avatar
same spot my amp is mounted but in a amp rack I made encased with plexi
so I am heading to the store now to pickup 2- 12v small fans.
I have a temp gun right now to measure temps under but reallylooking around for the best or some materials to put under the rack to break up the heat.but I know its not the best place to locate a amp.obvious yes but because of the exhaust worst place.
I can let you know in a day or so how much or how little the improvement of fans and a exhaust port will be.also is it mounted on anything mdf, or just floor board
Old Sep 21, 2005 | 05:35 PM
TRU681's Avatar
What or how are you running the amp because it has built in fans for cooling but not sure what ohms you're running it. Are you using it for bridged for sub or using 2 chanels for mids? Nice amp , I got 2 of them in mine, one for midrange & one for midbass.
Old Sep 22, 2005 | 01:56 PM
Mine is mounted directly to the floor board. I checked my ground yesterday and it checked out perfectly on my tester, so that isnt the problem. i run two 2 ohm DVC subs off of it and my amp has a 2 ohm load bridged. Kel Rx8, how did you build your amp rack? Im tryin to build one too.
Old Sep 22, 2005 | 01:58 PM
Kel Rx8's Avatar
built it out of 1/2 mdf (homedepot sell's this wood)take a look at the thread here on mycar.funny thing is I made 2 different styles of amp racks and chose the simple one I have in the car now.but let me know if I can be any help
Old Sep 23, 2005 | 06:00 AM
ayrton012's Avatar
Oh.. that's vented! As you know the floor of the trunk is very hot by the exhaust, and the two DVC gives an extra work to your amp. I think it's not the best place for an amp.
Old Sep 24, 2005 | 12:18 PM
mitchfried's Avatar
I have JL 500.1 and 300.4 amps mounted in the spare tire wheel well, covered over with carpet wrapped peg board. I poked holes in the carpet through the peg board for some ventilation. Even in the blazing central Florida heat, I have no problems (the amps themselves are three years old, formerly in my Mazda 6). Bottom line is that JL amps can handle the heat.
WranglerFan
Nov 5, 2017 09:35 AM
Randolph Alvarez
May 30, 2016 01:08 AM
ed0128
Sep 9, 2015 04:50 PM
