RX8 tune-up
Old Jul 22, 2003 | 11:06 AM
Haris's Avatar
RX8 tune-up
When is the main tune-up for the mazda rx8. I know mazda6 tune-up is at 75,000 miles, mazda truck is at 100,000 miles. Just wondering when do you have to do tune-up on the rx8?
Old Jul 22, 2003 | 02:07 PM
ggreen29's Avatar
The manual says major inspections of almost everything at 30k miles/48k km. Plugs are changed at 37.5k miles/60k km. MT and diffy oil are changed at 60k miles/96k km.
Old Jul 22, 2003 | 02:47 PM
vudoodoodoo's Avatar
Don't forget the timing belt at 60K miles!!! :D
Old Jul 22, 2003 | 02:55 PM
mantisflie's Avatar
I thought the 8 didn't have a timing belt?
Old Jul 22, 2003 | 02:56 PM
agisd's Avatar
do we have a cost estimate of the these?
Old Jul 22, 2003 | 03:15 PM
wakeech's Avatar
mostly harmless
hahaha... he's KIDDING!!
no worries mantis
as per the cost, it's not going to be more than a piston-powered car (of similar maintenance activities) by virtue of it's motor, if that's what you're worried about.
4 spark plugs, 4 wires, diff fluid, tranny fluid, bearing/joint/etc checks, chassis lube... nothing out of the ordinary.
Old Jul 22, 2003 | 03:23 PM
RotorMotor's Avatar
Senior Member
CHEAP!! At least at the rate I'm going! I was parked in the same lot as a Jiffy Lube yesterday and they offered to change my oil for free if I let him pull the car into the bay. :D I figured I was up to 500mi, so why not?
Old Jul 22, 2003 | 03:46 PM
Quick_lude's Avatar
Love to rev!
When do you need to do the valve job? 48K? :D
Old Jul 22, 2003 | 09:30 PM
N1XRR's Avatar
HAHAHAHHHAAAHHAHAHHAHHAA!!! BWAHH AHAHAHAAHAAA!!! Thats what they said about the RX7's too! HHAHAHHAAAA! Look at every 10k, depending on how you drive...maybe a little longer with this new engine.
Old Jul 22, 2003 | 09:55 PM
dragula53's Avatar
Forbidden Donut
also
gotta get new glow plugs.
Old Jul 22, 2003 | 10:04 PM
carnut's Avatar
Years ago, I had a 1974 RX-3 which practically ate spark plugs for breakfast. I finally gave up and got a set of lifetime "fire injectors" like the ones J.C. Whitney carried. (Yes, I know tests never showed them to be any better!) Interestingly, the electrodes never burned away like the regular plugs; it was the only solution I found. I imagine that problem was solved in later rotaries and won't be a problem with the RX-8.
Old Jul 24, 2003 | 11:46 AM
Superfan's Avatar
Member
My third gen RX-7 would need new plugs every 6-8k miles. At around $10 a plug, it get's expensive fast. Has anyone seen the plugs on the RX-8? I know they're NGK's but did they change the desgin from the last 7?
Old Jul 24, 2003 | 03:47 PM
neit_jnf's Avatar
Aren't the spark plugs Iridium-tip?? I thought those lasted very long...
Old Jul 24, 2003 | 06:02 PM
wakeech's Avatar
mostly harmless
they don't last long if it's running rich and they foul... the best you could do then is clean them, re-gap them, etc...
Old Jul 25, 2003 | 04:30 AM
Master Phu's Avatar
Your spark plugs will last longer if you follow the "short trip procedure" in the quick tips booklet. The Mazda guys that are touring the country told me that's the reason for "short trip procedure" being in the booklet, so that you don't foul up the spark plugs with unburned fuel. They also told me why white wasn't an available color in the U.S.
Old Jul 25, 2003 | 11:41 AM
DisneyDestroyer's Avatar
Careful, I bite!
ARGH, why not??? I would have loved that color!
Old Jul 25, 2003 | 12:02 PM
Master Phu's Avatar
*cough* Mazdaspeed *cough*
Man, these allergies are killer :D
Old Jul 25, 2003 | 06:41 PM
RX-8 Zoomster's Avatar
no worries mantis
wakeech,
Instead of saying someone was kidding, you could have just told him that someone was pulling his "timing" chain. :D
Old Jul 25, 2003 | 06:53 PM
Toadman's Avatar
Nomad Mod
Off to the garage, peeps.
05TR1CH
Apr 18, 2023 04:56 AM
SupraG
Sep 21, 2015 12:09 AM
vetteor8
Jul 25, 2015 11:43 AM
yapakanichi
Jul 20, 2015 02:17 PM
RX7.9
Jul 20, 2015 12:01 PM
