apotocki
09-14-2005, 09:45 AM
I recently changed to Eibach Pro springs. Love the look and the handling. However, as I previously posted in another thread a couple weeks back, I now have a 'problem' with what I think is under dampening of the rear. Going over 'bumps' at speeds of 10-35mph produce a loud jarring bang type of noise from the rear (and I've check everything out and see no problems - also, the bump stops were all trimmed 1 inch with the spring change). After researching and reading other posts (and magazines, etc.) I think the problem may be that the rear shocks are not beefy enough to handle the increased spring rate of the Eibachs (although based on a couple responses from others on this forum, I may be one of the only ones (with Eibachs) experiencing this?! Hmmmm.....
Anyway, I'm thinking about replacing the rear shocks and have found that there are really only a couple of alternatives (Koni sports or Tokico). I've pretty much decided on the Koni's......but......will I be doing any harm by only replacing the rear? I really don't have the $$$ to spend on all 4 right now and want to try and resolve the problem in the rear with the thought of replacing the front probably next spring.
Your feedback is appreciated. Thanks.
