Wierd issue with RB intake
Old Sep 14, 2005 | 05:29 AM
Discman2's Avatar
Rotary Noob
Ever since my car semi flooded/shut down/ or whatever happened last weekend there's been something really wierd going on.
Every other time I turn on my car it sounds like I have a stock intake. There's no throatiness. But then when I shut down and the next time I turn on it sounds like I have a RB intake(sounds throaty)....
It keeps alternating every drive.
At first I thought it was all in my head. Paranoia from what happened last weekend... But I just wanted to make sure there is no way something like this could happen. Hopefully everything is in my head
Old Sep 14, 2005 | 01:41 PM
Ole Spiff's Avatar
Under normal idle it should sound completely stock; mine does. It's only when the revs start to go up that I can hear the difference between stock and the RB intake, although now that I have the RB CAI installed it's not as noticable inside the car. It still sounds great under full throttle acceleration though.
Is there a difference between temps; hot/cold, time of day (first thing in the morning, etc.) when you start the car and it sounds like this?
Old Sep 14, 2005 | 02:36 PM
Tigster's Avatar
RX8 ADDICTED!!!
Try reseting the ecu In case you dont know how
press and hold the trip odometer button turn car to accessory with the key, hold trip odometer button until the odometer says "test" turn car off
then
turn key to accessory press brake pedal 20 times fast and the oil pressure gague will move up then back down. turn car off
now you reset the ecu. See is this helps
Old Sep 14, 2005 | 02:54 PM
SHOWOFF's Avatar
NOT SEARCHING
then
Those are just procedures to test the gages and reset eccentric shaft memory.
Old Sep 14, 2005 | 05:25 PM
olddragger's Avatar
your secondaries may not be opening. Lost of power?
OD
Old Sep 14, 2005 | 05:56 PM
Mzdarx8's Avatar
Disconnect negative battery terminal for at LEAST 2 hours. Reinstall, Hopefully
it will reset everything. If your secondaries are stuck, take it to the
dealer.
Old Sep 14, 2005 | 09:06 PM
Armaant's Avatar
Armaan
i can only hear the throatiness of my revi and duct at high rpms or with alot of throttle
Old Sep 16, 2005 | 11:47 PM
Good that's the way they made it. If you want loud get something that doesn't work for HP gain like a KN
Old Sep 19, 2005 | 09:48 AM
Discman2's Avatar
Rotary Noob
most of the times it's on the first drive of the day when it sounds off.
And yes, I am aware that when idle it's at a normal sound. And it "turns on" when revving.
I did the reinstall the other day, and it sounded ok this morning on my first drive.
And taking it to the dealer is not an option. They'll blame the secondaries on the intake, void warranty then charge an arm and a leg to fix.
Also. How would I know if the secondaries failed?
Old Sep 19, 2005 | 09:56 AM
epitrochoid's Avatar
Riot Controller
when you say you restart the car, are you restarting it warm?
when you flooded the dealer likely updated your PCM flash, which could be running cold idle maps leaner. i noticed with my canzoomer that the air/fuel mixture plays quite a role in the tone of the motor.
Old Sep 19, 2005 | 02:58 PM
Discman2's Avatar
Rotary Noob
never took it to the dealer.
Old Sep 19, 2005 | 06:30 PM
Riot Controller
hmm...if the car drives ok, it could just be a placebo...or maybe the LTFT was reset at some point, although AFAIK that doesn't effect startup maps.
as long as it sounds good at WOT you're cool lol.
xAgyex
Jun 3, 2026 03:47 PM
Warrior777
Jun 24, 2019 04:47 PM
FoxRacer600RR
Aug 31, 2015 06:32 AM
TheWhiteAce
Series I Engine Tuning Forum
Aug 6, 2015 02:26 PM
Belalnabi
Jul 17, 2015 07:48 PM
