Potential Turbo Problem
Old Sep 9, 2005 | 08:04 PM
RX8FOREAL's Avatar
Captain Spaulding
I brought my car in two days ago for recall and I received the updated R flash. I noticed this flash added fuel to top end particularly at boost. I had been reading around 11.5 - 12.0 and now I am reading below 11. I don't know how far below 11 because my AEM A/F gauge starts at 11. I also had a boost gauge installed today and at max boost was 5 lbs. The fact that I have a high flow cat and exhaust, I expected to be running a higher boost reading. I spoke to Benny at GReedy today and he seemed confused at that reading. He thought that with my set up I should see 7-8lbs. He said I might have a compression problem. Any thoughts or suggestions would be appreciated.
Old Sep 9, 2005 | 08:40 PM
zoom44's Avatar
fix the greddy map
Old Sep 9, 2005 | 08:52 PM
RX8FOREAL's Avatar
Captain Spaulding
Zoom44
How do I fix the Greedy map.
Old Sep 10, 2005 | 01:00 AM
Moostafa29's Avatar
Storm Trooper
By tuning it.
Old Sep 10, 2005 | 01:17 AM
adrian-1's Avatar
Ex- member.
I posted about the R-flash riching up my AFR's last week here.
You can get the map tuned but it'll be worthless in a month since the RX8 stock computer changes the fuel trim over time. The bottom line is the blue emanage isn't up to par on controlling the fuel for our cars since it adds to the existing stock fuel.
You'll need an EMS that controls ALL of the fuel (interceptor X, maybe emanage ultimate).
Old Sep 10, 2005 | 03:11 AM
zoomzoom_8's Avatar
i am finding that I have to reset my ecu two to three times a week just to keep safe a/f. Emanage is useless, if your rich, just hold out, it will lean out quickly
Saving for the interceptor, the threads on the negative battery cable are getting worn
Old Sep 10, 2005 | 06:23 PM
MadDog's Avatar
Consiglieri
I noticed my LTFT at -4% after about 2 hours of driving. Not sure what to do about it. I guess I could rig a relay to cut the battery, or get an Interceptor. The LTFT is the only thing buggin me. Aside from that, the emanage blue is doing a seemless job of controlling my car. I'm happy with it! :p
Old Sep 11, 2005 | 12:26 PM
Rasputin's Avatar
I guess the fuel trim has only a limited range. Say + or - 10%. Knowing the maw fuel trim, you just have to take it into account when you "tune" the e-manage. I don't really see the problem?
Fabrice
Old Sep 11, 2005 | 04:43 PM
MadDog's Avatar
Consiglieri
^ I thought about that. I think it can pull 20+% But, if the stock ECU ever gets reset, you'd have a VERY rich condition!
Old Sep 12, 2005 | 10:49 AM
D1GT-x8's Avatar
so im getting my warranty work soon should i tellem not to give me a flash?
Old Sep 12, 2005 | 11:16 AM
epitrochoid's Avatar
Riot Controller
well im sure they wont have a problem since you're warranty is toast because of the turbo anyway...hell at my dealer i have to practically hold their hand and show them how to flash the damn thing
Old Sep 13, 2005 | 08:19 AM
Rasputin's Avatar
Yes OK. But why would you want to reset anyway? You only reset when you disconnect the battery voltage to the PCM or during a PCM update (which you would not do anywore after tuning a Greddy kit).
Does a fuel trim hitting its limit (20% you said) will trigger a CEL or any fault mode?
Fabrice
Old Sep 13, 2005 | 10:03 AM
PUR NRG's Avatar
You don't want to but resets happen. Maybe you drain the battery or maybe you add something else to the car that requires disconnecting the battery to work on the electronics. Stuff happens.
________
Toys Fetish
JimmyBlack
273
Feb 10, 2020 10:23 PM
WranglerFan
Nov 5, 2017 09:35 AM
Randolph Alvarez
May 30, 2016 01:08 AM
Paul_Y
Sep 21, 2015 02:23 PM
ed0128
Sep 9, 2015 04:50 PM
