Offset Question...
Old Sep 6, 2005 | 10:55 PM
CGRX8's Avatar
ANGER
Offset Question...
I am looking to change out my rims from 19 x 8.5 with a 35 off set to a 19x8.5 with a 40 offset. will this work out for me? how much of a difference will this make.
i tried a serch but couldnt find anything quickly. I figured someone would know right away and be able to help me out.
thanks in advance.
Old Sep 6, 2005 | 11:05 PM
wheel will be 5mm into fender well...with 5mm less shock clearance
Old Sep 6, 2005 | 11:28 PM
ECHO1's Avatar
try this site, should you still need it
http://marksink.com/tire_wheel_offset/offset.html
Old Sep 8, 2005 | 10:41 PM
Brian Goodwin's Avatar
I run 18x9.5 all four corners with 45mm offset and 275s...no fit issues. Therefore, your change to 40mm offset will work fine and actually allow you to run wider rubber than before if you want to...
Brian Goodwin
Good-Win Racing
www.good-win-racing.com
Old Sep 9, 2005 | 08:16 AM
mikeschaefer's Avatar
I wanna rock! Rock!
crazyness! but i like it
I will have to search for pics of your car... if you havent' posted any, could you? Thanks
Old Sep 9, 2005 | 11:17 AM
Sure...
http://www.good-win-racing.com/mazda...topic.php?t=53
Be sure to see the BIG shot at the bottom of the page...
Brian Goodwin
Good-Win Racing
Old Sep 9, 2005 | 05:51 PM
I wanna rock! Rock!
That setup is going on my list of performance upgrades. I hope Enkei releases a version in gunmetal or even black.
Old Sep 9, 2005 | 05:52 PM
I just hope they get off that damn slow boat from Japan :D
Old Sep 9, 2005 | 06:03 PM
Im_DANomite's Avatar
I love GOOOLD
5 mm is about the thickness of a check book. not that much of a difference if you ask me.
hufflepuff
May 30, 2016 10:45 AM
NotAPreppie
12
Sep 24, 2015 03:22 PM
R2D2X8
Aug 17, 2015 08:47 AM
MolecularConcept
Aug 5, 2015 04:43 PM
