Anybody out there daily driving on 255/35/18's?
Old Sep 5, 2005 | 01:40 AM
El Kabong's Avatar
I'm interested in a set of autocross tires that I can also use as daily drivers. Anyone have any experience running 255/35-18 ?
What would the safety issues be WRT this size?
Thanks,
Kabong
Old Sep 5, 2005 | 08:04 AM
hemmingway_bg's Avatar
I am curious to. Also 275X35X18 on 18X9.5 wheels.
Old Sep 5, 2005 | 11:41 AM
Ole Spiff's Avatar
I've never done it but I'd imagine the issues would be darty steering on ridged or grooved road surfaces like they have on California freeways; more road shock transmitted to the car (less tire to cushion it); and greater vulnerability to rim damage from any kind of rut, speed bump, driveway lip, curbing, etc. Maybe you could have a set of rims with these tires for autocross that you put on for that day/event, then switch back to your normal wheels/tires at the end of the day? You could do it at the house so you wouldn't have to lug them to the track; switching for one day wouldn't be a big deal.
Just an idea.
Old Sep 5, 2005 | 11:51 AM
lurch519's Avatar
www.evoperform.com
my buddy runs 225/35 18 on his ep civic, much lighter car, has bent all 4 rims, so you may have issues.
Old Sep 5, 2005 | 01:03 PM
IZoomZoomI's Avatar
Boost needed
you won't have any issues with 255/18/35. The wheel diameter is the same, I know of a person that runs this setup, more tread = more traction. I don't know about going above that though.
Old Sep 5, 2005 | 01:42 PM
Moostafa29's Avatar
Storm Trooper
I think PURNRG has 255/40/18. That is the route I am thinking about going, so there is a little more tire to work with versus the 255/35/18.
Old Sep 6, 2005 | 02:43 AM
IZoomZoomI's Avatar
Boost needed
you lose some gearing advantage with 255/40's compare to 35's.
Old Sep 6, 2005 | 07:17 AM
Moostafa29's Avatar
Storm Trooper
With turbo, I doubt its a huge deal.
Old Sep 6, 2005 | 10:01 AM
PUR NRG's Avatar
Bent rims can be from tire profile, sidewall stiffness and/or wheel quality. The key factor is the wheel itself--most cases I've heard of are due to "cheap" wheels that don't have much safety margin.
The RT615s in 255/40-18 have the same outer diameter as stock--or close enough to it to make no difference. A lower profile tire will give you better gearing which is always a benefit in autocross but as a daily driver you throw your speedo and odometer off. Speedo isn't so bad but odo means you're artificially inflating the reported mileage. Not such a good thing when it comes time to sell the car.
________
Weed
projectr13b
Mar 1, 2019 09:00 AM
Ugafan97
SE For Sale/Wanted
Apr 28, 2016 03:35 PM
tigg.z
Aug 26, 2015 09:51 PM
RX7.9
Jul 20, 2015 12:01 PM
