View Full Version : Two Recalls today!!
sean4828
09-02-2005, 07:45 PM
I got an envelope today from Mazda with 2 Recalls one is for a Front Lower Arm Ball Joint it says Ball Socket Joint of Lower Arm may have cracks. The other is for a Fuel Tank Recall it says if RX 8 is parked and the engine is operated at High RPM's excessive heat buildup may cause problems with Ox Sensors, the neutral switch and backup lites causing MIL illumination and exhaust emission and drivability will be affected. It could also lead to problems with the Parking Brake cable tube causing loss of Park Brake function, malfunctions of the gas gauge and possible damage to the fuel tank causing fuel leaks and a possible fuel fire?? Anyone else get this good news?? I called my Dealer today and I will have them both checked out next Wed.
mikeb
09-02-2005, 07:48 PM
yes I got it to
check out the tech gargage
many have had it done or looked at already
Krankor
09-03-2005, 03:08 AM
I got the fuel tank one.
Krankor
05 Shinka 6MT
JeRKy 8 Owner
09-03-2005, 03:24 AM
I got both in the mail today as well. My only question now is where the fuck is the navigation upgrade software at? :D
mikeb
09-03-2005, 08:55 PM
good question^^^^^^^
Tamas
09-03-2005, 09:45 PM
I got an envelope today from Mazda with 2 Recalls one is for a Front Lower Arm Ball Joint it says Ball Socket Joint of Lower Arm may have cracks. The other is for a Fuel Tank Recall it says if RX 8 is parked and the engine is operated at High RPM's excessive heat buildup may cause problems with Ox Sensors, the neutral switch and backup lites causing MIL illumination and exhaust emission and drivability will be affected. It could also lead to problems with the Parking Brake cable tube causing loss of Park Brake function, malfunctions of the gas gauge and possible damage to the fuel tank causing fuel leaks and a possible fuel fire?? Anyone else get this good news?? I called my Dealer today and I will have them both checked out next Wed.Geez.
shinka213
09-03-2005, 09:57 PM
Got mine yesterday!!!!!
GAS TANK!!
mmats69
09-03-2005, 11:09 PM
I've actually moved since I bought mine. Anyone be able to tell me how I can get my address changed. Drop me a pm.
LiveBlues
09-03-2005, 11:31 PM
You can just call Mazda North America. 1-800-222-5500
midlifer
09-04-2005, 01:41 AM
got 1 yesterday, gas tank.
______
09-04-2005, 01:44 AM
got mine for the ball socket
Elara
09-04-2005, 03:58 PM
See the posts in the tech garage about the recalls :) Closed.
