Aftermarket plugs and wires
Old Sep 1, 2005 | 10:46 PM
Armaant's Avatar
Armaan
What exactly do aftermarket spark plugs and ignition wires do? I've seen a couple different sets of wires for sale but what effect does this have on the car? Also I i got something like the rb ignition wires what about a distributor cap?
Old Sep 1, 2005 | 11:05 PM
Cynic10508's Avatar
RX-8 doesn't have a distributor cap. Four plugs all with individual ignition coils fired by the ECU.
Old Sep 1, 2005 | 11:09 PM
Armaant's Avatar
Armaan
^didnt know that...so basically getting upgraded wire would do.....what for performance/relaibility/anything?
Old Sep 1, 2005 | 11:19 PM
The wires will be more heat resistant.
Old Sep 1, 2005 | 11:24 PM
Armaant's Avatar
Armaan
but what im asking is what does that heat resistance do? does it only make the wires last long? Does it help hp? gas milage? idle? what are all the postives that come from replacing your ignition wires?
Old Sep 5, 2005 | 10:48 PM
RoXanneBlack8's Avatar
stop flooding ur engines
yes they will withstand the heat better than the stockies. the most important plus of aftermarket wires is that they will have less electronic resistance (Ohms, to the electrically inclined)
________
HERBAL BLENDS TO VAPORIZE
Old Sep 6, 2005 | 12:54 AM
Armaant's Avatar
Armaan
Thanks for all the info....i'm basically trying to find out if replacing my stock ignition wires with wires that can handle higher heat and have less electric resistance will do anything for the performance of my car. I.E. - HP(though i doubt it), smoother idle, gas milage....in laymans terms will it effect any of these...mind you this is with some aftermarket parts - high flow cat, revi and duct, dyno tuned cz.
Old Sep 8, 2005 | 06:50 AM
mikeschaefer's Avatar
I wanna rock! Rock!
smoother idle and better gas mileage... maybe I wouldn't count on noticing much though.
My plan is to wait until the maintenance period comes around (or maybe a bit sooner) for the plugs and then put on bigger aftermarket wires at the same time.
Old Sep 13, 2005 | 11:40 PM
StealthFox's Avatar
better spark for ignition too, along with better gas mileage and smoother idle, all very minor though, if you do iridium spark plugs, some nology or RB spark plug wires, and new grounding you should be able to feel this(although grounding alone wont affect much because the car is newer and once old grounds get mucked up and you re ground it makes a noticable 3hp difference or so)
Old Sep 13, 2005 | 11:43 PM
Gomez's Avatar
Shifty Bastard.
Iridium plugs come stock from the factory.
Old Sep 14, 2005 | 12:14 AM
Fanman's Avatar
I would caution you on the Nology wires. we had a poster here who melted his (spark) plugs when he used them.
Old Sep 14, 2005 | 11:59 AM
Armaant's Avatar
Armaan
anybody tried the rb wires? And did i read that wrong or is there actuqlly a possibility or picking up 3 hp wired just new wires?
Old Sep 14, 2005 | 12:10 PM
RX8FOREAL's Avatar
Captain Spaulding
Stay away from nology wires. I had them installed one year ago. They were fine for about 3 months and then they fried my coil packs, which I was lucky to get warrantied from my dealer only because he did a lot of bolt on work for me !!!!
Old Sep 15, 2005 | 10:07 PM
StealthFox's Avatar
sorry, i meant to put NGK plugs, was typing too fast
Old Sep 15, 2005 | 10:08 PM
StealthFox's Avatar
bah, it doesnt add power (if anything .000001 whp probably ), it will increase your gas mileage a smidge but it will mostly improve your idle
Old Sep 15, 2005 | 11:13 PM
Armaant's Avatar
Armaan
so at about 80 bucks for wires from rb and putting them in myself does anyone think they're worth it? Will it make a difference once i tune it with a cz?
Old Sep 20, 2005 | 11:45 AM
Jaguar_MBA's Avatar
Nope doubt they will make any difference. Save your money for a real performance mod.
ironj221
36
Jan 20, 2026 08:28 PM
Ugafan97
SE For Sale/Wanted
Apr 28, 2016 03:35 PM
Sifu
Aug 30, 2015 10:51 PM
dancingdan42
Aug 19, 2015 09:29 AM
CMRine04
Jul 29, 2015 02:07 PM
