camber kit or what?
Old Aug 30, 2005 | 09:19 PM
sampson's Avatar
rotary noob
camber kit or what?
OK...I do not know much about alignments other than you should get one done anytime you change suspension components. I put the H&R springs on my car and I am tucking my front wheels. I was hoping that getting an alignment could fix them so i do not have uneven tire wear problems. I took my car to Sears and the tech told me that the drop was too low and the numbers he put into the computer would not "take". He told me that all he could do is adjust it so as to minimize my tire wear. Is there any way i can get this condition fixed so i dont kill my tires? Are there any camber kits for the 8 or can it just be fixed by doing an alignment? Enlighten me!!
Old Aug 31, 2005 | 06:22 PM
Soundave's Avatar
Decepticon
I would like to know the answer to this as well. The shop I went to told me the same thing. My Tanabe's dropped it enough to cause a 2 degree change in camber.
Old Aug 31, 2005 | 08:51 PM
sampson's Avatar
rotary noob
Can anyone help me?
Old Aug 31, 2005 | 09:48 PM
Take your car to a good alignment shop. You may not be able to get stock camber...but you really don't want it anyway :D
I am running -1.5 deg camber frnt and rear with 7 deg castor.....and zero toe. Handles great!
Camber kit won't work on this car ...not a strut type suspension!
Old Aug 31, 2005 | 09:57 PM
sampson's Avatar
rotary noob
how is the tire wear with that setup? i don't want to kill my tires.
Old Aug 31, 2005 | 10:57 PM
DPE's Avatar
DPE
What dannobre said. Incorrect toe settings will kill tires far more quickly than anything, so just make sure you're within spec on toe and then get camber between -1.0 and -2.0. The car seems to have a good amount of camber adjustment, so I'd be surprised if you couldn't get there even with very aggressive/low springs. And for toe, you'll certainly be able to get it back to spec regardless of suspension mods. To a point, you want more negative camber. In our opinion -2.0 is about as much as you'd want on the street in most cars, but it varies from car to car.
Dave, how are the springs and bars treating you, other than the alignment thing?
Old Aug 31, 2005 | 11:24 PM
No problems at all.....
Old Sep 1, 2005 | 12:57 PM
Soundave's Avatar
Decepticon
The car handles amazingly. It feels planted through long sweeping turns and the rear doesn't break loose as easily anymore. The bars were a great deal! Thanks! I still have the poly-u bushings if you need them
Old Sep 3, 2005 | 01:25 AM
juikster's Avatar
Im 8 drifting on a budget
My tanabe springs dropped my car 1.25 /1.5.....my front end needed little adjustment ,my rear end was adjusted in order to restablish vertical rim alignment.thats all...mine was done by a firestone shop and this guy was know nubie at alignment ,but he said it was a simple adjustment and my tires are wearing just fine after 7000 miles...
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
duworm
Oct 1, 2015 04:57 PM
Digitz0070
Sep 27, 2015 07:49 AM
Digitz0070
Sep 25, 2015 10:58 PM
