Help please with greddy sp2 exhaust!
Old Aug 24, 2005 | 04:32 PM
LiL BenNy's Avatar
Bubblicious? DEF.
ok so i need to know what i need. i bought this used.. what i need to know is do i need a gasket or some sort in between this part before i bolt together.. theres not one in the stock exhaust right? cuz the stock is clamp as this is 2 bolts...
PLEASE help i REALLYYYYYYYYY want to install this ASAP i cant wait! :o
Old Aug 24, 2005 | 04:55 PM
foxman's Avatar
Torque is Good
The stock exhaust does not bolt together in the same fashion in that location.
There should be a gasket in there yes, mine came with one, you can also add something like this product as well which you can get at your local hardware store.
PERMATEX ULTRA COPPER Hi-Temp RTV Silicone Gasket Maker
http://store.yahoo.com/autoaccesscon...lcohirtvs.html
Old Aug 24, 2005 | 04:59 PM
LiL BenNy's Avatar
Bubblicious? DEF.
THANK YOU SO MUCH.
ps do you know what bolt sizes to use?
and dont they make gaskets in metal too? if so when i go to the store what do i ask them for? everytime they computer searched rx8 and of course since its new they dont have any...
Old Aug 24, 2005 | 05:05 PM
foxman's Avatar
Torque is Good
My recollection is they are 10mm bolts, don't recall the length but someone else might. I tend to just use whatever works/fits in that situation.
Since you don't have the original gasket, I would just get the high temp gasket maker instead and use it. It will do the job as well or better, just make sure you get a complete seal including the areas around the bolt holes. I actually used the high temp gasket maker and the gaskets both. I believe the gaskets that come with the GReddy are not metal but something else. I doubt you will be able to find them unless you got them from a dealer who sells that exhaust. As long as you get a good, complete seal from the high temp gasket maker, you should be find and leak free.
Old Aug 24, 2005 | 05:11 PM
LiL BenNy's Avatar
Bubblicious? DEF.
alright foxman you are the man. thanks gonna go pick some up tonight!
Old Aug 24, 2005 | 05:46 PM
FLybOi drE's Avatar
uhh...its not 10mm...usually exhausts uses bigger bolts. the midpipe uses 14mm bolts so use that...oh and the o2 sensor requires an open wrench 21mm and be careful when you take it out or you'll pay 200 for another o2sensor.
Old Aug 24, 2005 | 07:02 PM
staticlag's Avatar
The Professor
The permatex doesnt work that well, it melts.
Old Aug 24, 2005 | 07:28 PM
foxman's Avatar
Torque is Good
mine hasn't
Old Aug 24, 2005 | 07:30 PM
foxman's Avatar
Torque is Good
why would he be messing with the o2 sensor with a cat back exhaust?
Old Aug 24, 2005 | 08:20 PM
expo1's Avatar
He's as bad as Can
Here is what it looks like, don't know if this helps.
Hey don't you live in Jersey? I could drop it in the mail, it's an extra. have to PM me fast, I am going away thurs.
Old Aug 24, 2005 | 08:50 PM
staticlag's Avatar
The Professor
mine hasn't
Mine oozed out of the cat->muffler joint and now is a blob hanging off of the pipes. It was fine for about four or five days though right after I applied it but then the heat made it disintigrate. Its done that to me 2 times before I actually had to get the real gasket.
Old Aug 24, 2005 | 11:42 PM
LiL BenNy's Avatar
Bubblicious? DEF.
nah thanks tho expo i found one at advance autoparts.... im prally gonna but the metal one and the silicone with it.... thanks alot for the help everyone
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
mdl0209
May 23, 2019 05:46 PM
Jb4ker96
Sep 27, 2015 10:06 PM
