Sub/Amp Question
Old Aug 24, 2005 | 09:03 AM
DreRX8's Avatar
Sub/Amp Question
So I've hulled out my Polk/Momo 8" sub--I'm pushing it with an Alpine 5 channel amp with 200 Watts RMS; I'm thinking of going ahead and going with a 10" sub this time around--my question is if my amp is 200 watts RMS; would it have a problem pushing a sub that is rated as 300 watts rms max? The 200 watts falls within the RMS range but would the bass be better if I just matched it with the 200 watt RMS 8" sub I had or if I went with a 10" with a closer max RMS to what the amp pushes? I'm a sem-inovice when it comes to bang in the trunk.
Old Aug 24, 2005 | 10:42 AM
rkostolni's Avatar
I generally go with an amp that has 50-100% higher rms rating than the sub requires. If its a cheaper brand amp I go closer to 100%, because they overate. If its a better brand 50% will usually be sufficient since they underrate. You can always turn the gain down, but you can only turn it up so far.
So for a 200wrms sub, if its a california profile amp, I would look for one that's about 400w. If its a jlaudio amp, then 300w would be good.
Having too much power is far better than having too little power since the average power in a clipped square wave is far greater than the average power in a sine wave of the same magnitude.
Old Aug 24, 2005 | 10:52 AM
DreRX8's Avatar
Thanks for the info--Its an Alpine amp--I've been searchin online this morning--I'm leaning toward an Infinity Perfect 10" or a Polk/Momo 10".
Old Aug 24, 2005 | 11:04 AM
guy321's Avatar
Humpin legs and takin nam
Remember it this way.. technically the amp is not "pushing" power to the sub.. the sub is drawing power from the amp.
Old Aug 24, 2005 | 12:36 PM
DreRX8's Avatar
Right--but thats just the lengo I grew up with from cats poppin' trunks in Delta 88s and 'Lacs.
Evan Gray
Nov 24, 2015 01:00 AM
nferguson88
Oct 6, 2015 12:45 PM
urbanvoodoo
Sep 30, 2015 12:41 AM
pjwermuth
Sep 28, 2015 11:36 PM
kody59
Sep 28, 2015 03:43 PM
