Had a flat tire?
Old Aug 22, 2005 | 12:35 PM
1.3L's Avatar
Had a flat tire?
How many of you have had a flat tire on your RX-8? And if so, did the factory fix-a-flat kit do any good?
1.3L
Old Aug 22, 2005 | 01:27 PM
KYLiquid's Avatar
Oil Injection
There was a post on this a little while ago...
The 'Flat Repair Kit' that comes with the car is only really good for an emergency. Once you use it, the tire is no good.....so your basicaly throwing away a tire cause of a screw hole or whatever. Since the kit cant repair a major failure (blow-out, ect) it will only fix tires that could prolly be repaired, and then the tire is useless, tires that it cant fix would be useless anyway.
Bottom line, if your out in the middle of nowhere, or its not safe to stay there then use the kit, otherwise just get it towed.
Old Aug 22, 2005 | 01:47 PM
wedge357's Avatar
ShinkaMan #748 SV6P
Careful or you'll get flamed for saying the tire will be unfixable. Apparently, some other members found places that will clean off the goo and fix the the flat. Mazda Manual states that the tire would need to be replaced once the repair kit is used so I'm also not backing down from recommending it either.
Use the Mazda Roadside Assistance instead or just pay for a $50 tow to the nearest repair shop instead of buying a new tire for a lot more.
Old Aug 22, 2005 | 02:05 PM
Frostee's Avatar
I am Goober Wafflelips
i did a post like that a while ago:
https://www.rx8club.com/showthread.p...&highlight=goo
Old Aug 22, 2005 | 02:58 PM
1.3L's Avatar
Not exactly; I'm looking for actual experiences.
See above
1.3L
Old Aug 22, 2005 | 05:32 PM
KYLiquid's Avatar
Oil Injection
from looking at the stuff it looks like the same stuff in those cans of fix a flat and I know some versions of that stuff ( and maby its changed, this was a few years ago) the stuff would stick to the inside of the tire and most of the time couldnt (easily) be removed
Old Aug 22, 2005 | 05:53 PM
Labop's Avatar
I've gotten four flats, three were nails, the other was a gash. I was always within a short distance of a garage so I haven't used the fix a flat.
I used the compressor twice. I'd gotten the flat in the afternoon and it leaked out overnight to an "awww sh**." in the morning. compressor works great! :D
Old Aug 23, 2005 | 04:16 AM
Mikelikes2drive's Avatar
have just gotten a nail in my tire and screw in my tire... both times i just drove it to a gas station... filled it up with more then enough air and drove it to american discount tire company and got it repaired for free
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Rx8 VA Guy
Jun 4, 2016 12:42 AM
Michael Bryant
Oct 12, 2015 03:07 PM
duworm
Oct 1, 2015 04:57 PM
