OK to wax windows?
Old Aug 17, 2005 | 04:13 PM
lshu's Avatar
Driving makes me :)
OK to wax windows?
Is it OK to wax the windows/sunroof? I'm not sure if wax negatively affects the rubber trim around the window.
Old Aug 17, 2005 | 05:58 PM
RX8rider's Avatar
Are you kidding me? Why the heck would you wax the windows? Just get yourself some Windex.
Old Aug 17, 2005 | 06:03 PM
RX-8 8-XЯ's Avatar
DO IT!!!! Go for the gusto, I don't see anything bad happening BTW, I can't believe this question was asked
Old Aug 17, 2005 | 06:08 PM
Labop's Avatar
Uhm, if you're going to wax them, do it right. Use RainX. It's designed to use on glass and it helps the rain bead up and channel away. They also make an interior anti-fog product. I'm not saying regular wax is bad for the windows, but I wouldn't do it. IMO:
Regular Wax + windows =
RainX + windows = :D
Old Aug 17, 2005 | 06:22 PM
tiggerlee's Avatar
May Cause Anal Leakage
I can. it's not that far fetched for people to wax their windshields/ back windows etc.
We did it years and years ago long before products like Rain-X were available. I don't think it would hurt anything,may be a bitch to get off the trim though. Like labop said just get some Rain-X.
Old Aug 17, 2005 | 07:54 PM
Haze's Avatar
Make sure that you keep the wax off the rubber as it can discolor it, but an old polishing trick is to wash your windows with whatever you like best then polish them with dry newspaper and they shine right up. Try it and see if you like it, and if you don't; hey no harm done.
Old Aug 17, 2005 | 08:25 PM
Nubo's Avatar
Lubricious
You may find that waxing the windshield makes the wipers chatter badly; maybe not at first... You'd be better off with RainX, which is designed for the purpose.
RainX is surprisingly effective. A lot of times you don't even need the wipers, and condensation rolls off as soon as you get underway, leaving clear windows -- so it's useful on all the windows not just the windshield. The problem I had was with the chattering. As long as you keep up with the applications you're fine but when it starts wearing off the wipers start chattering across the windshield. Then you have to decide whether to scrub the remainder off or go back to using the RainX.
Old Aug 17, 2005 | 08:43 PM
Flawless's Avatar
I don't see a problem in this as long as you don't get it on the rubber. If you get it on the trim you will have a tough time getting it off most likely. I have waxed my headlights as well as my rims before so I don't see why you couldn't wax your windows as well. There is a product RainX as mentioned above that repels water. I've used it in the past and wasn't all that impressed with it because it's only effective in 50+mph (not city driving).
Old Aug 17, 2005 | 08:48 PM
tiggerlee's Avatar
Actually rainx has a new product out called Winshield Wax.
http://www.rainx.com/BB/default.htm
Old Aug 18, 2005 | 07:21 AM
draco067's Avatar
Cap'n Limekitten says arr
I use Zaino on all of my windows, inside and out, EXCEPT the windshield. Keeps them looking crystal clear - AND easy to wipe clean.
Old Aug 18, 2005 | 10:00 AM
wankleman's Avatar
Georgia RX-8 Club member
if your worried about waterspots use NuGlass
Old Aug 18, 2005 | 11:20 AM
I've heard of waxing the tail lights on your car but windows?! whoa...
Old Aug 18, 2005 | 11:48 AM
rob.rotor's Avatar
I thought this question was a joke so I just had to pop in and take a peek. Just turned out to be a stupid question. Now I'm disappointed :-(
Old Aug 18, 2005 | 04:37 PM
lshu's Avatar
Driving makes me :)
Thanks for the responses. The reason I asked is because I wanted to prevent chips to the windshield from sand and rocks, which my previous car had. Wax seems to protect the paint finish pretty well from small rocks, so I was thinking it might be good for protecting the windshield. Now Rain-X wouldn't do that, would it?
Old Aug 18, 2005 | 04:49 PM
tiggerlee's Avatar
No. Rain-X just makes the water bead so it runs off easier and helps keep windows cleaner and clearer. If you want to wax them go ahead it's your car. It's not going to hurt anything. :D
Old Aug 18, 2005 | 09:18 PM
RX-Nut's Avatar
8 the HARD way.
I found that in the long run waxing your windows makes for some funky buildup that really obscures your vision when the glass gets wet. Unless you wax it religiously you may find yourself in the rain one day and can't see the road.
I dunno maybe it was just a fluke problem on my glass.. who knows.
Old Aug 19, 2005 | 05:47 PM
Nubo's Avatar
Lubricious
That wasn't my experience at all. The RainX effect would begin almost as soon as the car began moving. It really is quite impressive if you're willing to keep up with the applications.
Old Aug 19, 2005 | 05:54 PM
RedSheDevil's Avatar
.:. causing mischief
Shout out for RainX...it's awesome and really does work!! Think I may go put some on now...thanks for the reminder!!!
Old Aug 19, 2005 | 08:25 PM
vectorwolf's Avatar
Totally confuzzled...
I thought you might've been asking about Wax as part of the cleaning process... In that case, I'd suggest using a clay bar to completely remove all debris and leave your window so clean you can't even tell it's there. Not sure at all what you might use to help prevent rock chips and such... My window always seems to have a thin layer of spots from debris and bugs that I'd LOVE not having to deal with.
Old Aug 28, 2005 | 08:45 AM
hondasr4kids's Avatar
I wouldn't recommend waxing the windows. at night the lights will reflect the actual wax and make it hard to see out of them. They will look foggy. At least that's the problem
I had.
Old Sep 22, 2005 | 02:31 PM
Asmoran's Avatar
Just wanted to second (fifth?) the RainX. I've used it for years and it works wonderfully. The only thing is that you have to keep up the applications. After couple stormy months you need to re-apply it.
Also, it can be a pain getting it off if you let it dry too long. A damp cloth works wonders though.
Old Sep 22, 2005 | 02:43 PM
Booster MPS's Avatar
Clay bar alone will do wonders for you
Jst4fun
Mar 5, 2021 07:16 PM
BillBertelli
NE For Sale/Wanted
Mar 19, 2016 03:01 PM
garethleeds
Europe For Sale/Wanted
Nov 19, 2015 06:32 AM
Steve Dallas
RX-8 Racing
10
Oct 7, 2015 10:30 AM
nferguson88
Oct 6, 2015 12:45 PM
