would this shifter fit
Old Aug 17, 2005 | 12:58 AM
veilsidev1's Avatar
http://cgi.ebay.com/ebaymotors/MOMO-...92955765QQrdZ1
hey watup guys, im ignorant in this subject, would this shifter fit the 8
Old Aug 17, 2005 | 02:01 AM
Noguni's Avatar
Momo usually come with adapters that make it fit. You should just look into voodoo shift *****. The voodoo ***** screw right on and look alot better too.
Old Aug 17, 2005 | 02:06 AM
staticlag's Avatar
The Professor
Wow that MOMO one looks cheap.
Voodoo is definetly the way to go
http://www.teamvoodoo.com/Voodoo/TeamVoodoo.html
or
I honestly don't understand peoples' facination with 'MOMO' I hate the company simply because I think the name 'peach' is silly.
Old Aug 17, 2005 | 08:12 AM
M-ster's Avatar
Most if not all Momo's ***** are universal. How it works is it usually has a fairly large hole that slide right on to the gear shaft. Then its secure by 2-3 small allan screws from the side on the lower part of the ****. And wat it does is usually demaging the screw threads on the gear shaft.
As you know our gear **** is screw right on to the gear shaft, so are most other Mazda's makes. And the voodoo's are so popular is because they are made to fit the Mazdas. Screw right on.
So if dont intend to use back the original ****, by all mean, you can try the Momos.
Old Aug 17, 2005 | 08:43 AM
scarroll's Avatar
Murphy is my copilot.
I have a wooden Momo **** in my Miata. I love the ****, but was horrible as/is, with its "universal" install method. There is a device called the tight fit adapter, for around $19 bucks. That makes this **** PERFECT! The adapter uses the same thread pitch as the RX-8 shifter, so it threads right on.
http://store.miataparts.org/timomiad.html
here is the **** I use
http://store.miataparts.org/momospherewood.html
I put it on the RX-8 for a while to see if I liked it.
This particular **** needs a little more weight, to match the feel of the stock 8 ****.
You can add lead ballast under the top metal part to achieve this.
Old Aug 17, 2005 | 11:09 AM
scarroll's Avatar
or
MOMO has the brand marketing, - "Hell, it's in a F1 Ferrari, I gotta get that"
It's all over racing marketing and even video games...
I am a fan of Voodoo's too / top quality, MOMO's selection is just overwhelming...
I don't understand the peach reference, please explain.
Is momo "peach" in another language?
Old Aug 17, 2005 | 01:52 PM
staticlag's Avatar
The Professor
Momo = "peach" in Japanese.
I think its a bit absurd to have the word "peach" plastered all over your car.
Old Sep 2, 2005 | 01:06 PM
xhilar8's Avatar
Voodoo is definitely the way to go. Just installed a Pearl Magnum on my 8 and it is awesome.
Old Sep 15, 2005 | 01:00 PM
slllygrl10's Avatar
EX-Member
I wonder if voodoo shift **** will fit my a/t. Will it?
theblinkof
Oct 4, 2023 05:24 PM
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
hufflepuff
May 30, 2016 10:45 AM
Quiggs321
Sep 30, 2015 05:34 PM
GK1707
Sep 27, 2015 07:33 PM
