Owners of 17x9 on all 4?
Old Aug 15, 2005 | 04:23 PM
Spin9k's Avatar
Momentum Keeps Me Going
I did a search, but can't find anyone who actually says they HAVE 4x 17"x9" of some offset on their car. Lots of speculation/talk/ideas, but that's it. It seems that would provide the best track combo with some 265/40/17 or 275/40/17 tires on track.
Anyone actually OWN and DRIVE this setup? Opinions, observations?
Old Aug 15, 2005 | 05:27 PM
Three Sided Object's Avatar
I'd like to know also.
Old Aug 16, 2005 | 12:57 AM
rotarenvy's Avatar
I'm running the 18x9 39+ (235) all round and after checking it would be close with 17", wider rubber, more camber with the stock suspension. I can get my hand between the rim and spring and estimate clearance to be 2" or so. there is an excelent chance it will fit std but if you want to run lots of camber maybe not
Old Aug 16, 2005 | 01:28 AM
BigOLundh's Avatar
#1 Legend
i'd like to know as well.
Old Aug 16, 2005 | 02:43 AM
18X9.5 45 offset with 275-35-18 tires will fit all around I've been told........
I will see soon :D
Old Aug 16, 2005 | 03:01 AM
rotarenvy's Avatar
spin 9k I was going to write how 18x9 would be almost as good and compare the different buddyclub P1 QF rims (which are dam light!) as an example.
17x8 45+ 6.1kg
17x9 35+ 6.5kg
18x9 35+ 6.7kg
but I reckon 17x9 35+ would fit. it will stick out 5mm on the front but you can run some more camber. I'm sure you can find some other 17" winter wheels to compaire the 35+ to.
Old Aug 16, 2005 | 06:42 AM
Spin9k's Avatar
If there is so much inside room to shock, wouldn't a 45 or 50mm offset just fit right in there with no problem, no high neg camber?
Old Mar 24, 2006 | 12:53 PM
shinronin's Avatar
i ordered 17x9 ET40 5zigen fn01r's today in mat black. 255/40-17 advan neova's will be mounted when they arrive. i'll post pics when the wheels go on.
Old Mar 24, 2006 | 01:09 PM
this thread is old, you can run at least 18x 10" wheels with 285/30 tires ...
Old Mar 24, 2006 | 01:12 PM
shinronin's Avatar
just updating it with more data points. repeating data/info in multiple threads makes everyone's head hurt.
theblinkof
Oct 4, 2023 05:24 PM
mdl0209
May 23, 2019 05:46 PM
Quiggs321
Sep 30, 2015 05:34 PM
FubarI33t
Sep 28, 2015 08:45 PM
