Ram Air Duct, temperature sensor in the way?
Old Aug 13, 2005 | 08:45 PM
mazdaexe's Avatar
I installed both the revi and the ram air duct. The revi was a clean install, everything fit in perfectly. As for the ram air duct, I had a difficult time trying to align the duct w/ the two screws from the foam. I noticed that the temperature sensor was in the way. Anybody else had the same problem?
Old Aug 14, 2005 | 02:11 AM
did you unattatch the cord teather clamp as per the instructions????
if you did my guess is that you did not move the sensor wire enough out of the way.
hope this helps.
Old Aug 14, 2005 | 06:49 AM
rxeightr's Avatar
M0D Squad -charter member
^^^ What swoope said.
Old Aug 14, 2005 | 07:22 PM
mazdaexe's Avatar
yes. I detached the cord teather clamp. Its the temperature sensor itself that seems to be in the way. I got the duct installed and running, just that, it seems to be squeezing the actual sensor a bit. thx
Old Aug 14, 2005 | 07:29 PM
didnt have that problem. the notch in the duct fit the temp sensor perfect. my guess is to move around the wire a bit, but would i take the nose off to do it????
i would wait till i had something else to do under there.
Old Aug 14, 2005 | 07:45 PM
Ok, I'll drink to that.
WranglerFan
Aug 21, 2022 01:29 PM
JimmyBlack
273
Feb 10, 2020 10:23 PM
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
yapakanichi
20
Sep 10, 2015 07:17 AM
