Revi, vacuum hose removal
Old Aug 13, 2005 | 01:16 PM
mazdaexe's Avatar
Hi all, trying to install the revi, but Im having a hard time trying to remove the vacuum hoses. Any tips please?
Thanx
Old Aug 13, 2005 | 02:43 PM
Dragonrider's Avatar
Of the Black Dragon
Lightbulb New to Working on cars?
Thanx
Vacuum hoses tend to sort of bond themselves to connecting nipples.
Since you don't reuse any of the parts, take a sharp knife and make a slit along the vacuum hose from the base of the connecting nipple to the end of the connecting nipple. The vacuum hose will simply pop off after that.
Old Aug 13, 2005 | 04:37 PM
staticlag's Avatar
The Professor
^Thats what I did
That hose is cheap rubber, I'm sure if you did need to replace it, it would be easy to find.
Old Aug 13, 2005 | 07:24 PM
mazdaexe's Avatar
thanx guys, I used a tool called "strength" and pulled it out.
Old Aug 14, 2005 | 12:48 AM
rotarenvy's Avatar
or you could just wriggle it from the bottom. just pick/pull on the bottom with a finger nail at one point and work around the tube.
Old Aug 14, 2005 | 03:30 AM
Xyntax's Avatar
THREAD KILLER
I used pliers to push it down from the top end part. It didn't even take strength to unlatch it. I guess I can say, I used a tool.
Old Aug 23, 2005 | 04:56 PM
Umbra's Avatar
I just pulled hard.
Evan Gray
Nov 24, 2015 01:00 AM
Racingjunkie
Sep 29, 2015 05:05 PM
xAgyex
Sep 28, 2015 08:54 AM
Learners_Permit
Sep 27, 2015 07:38 PM
