Upgrades?
Old Aug 12, 2005 | 03:23 PM
DesertRoadRnnr's Avatar
Upgrades?
I've had my completely stock RX-8 for a few months now and have had it in one open road event. I was in the 100MPH class which required speeds from 110 to 115. In practice though I ran up to my tech speed of 120. At 6000 feet elevation in 100 degree hit I started to lose accelleration response at 120. I have moved up in class and will probably need to run up to 120. My questions are: Does this sound typical considering the conditions? And, what are the first upgrades I should be looking at?
Old Aug 12, 2005 | 03:25 PM
zoom44's Avatar
we dontknow what car you have
Old Aug 12, 2005 | 03:26 PM
2004 RX-8 6 speed
Old Aug 12, 2005 | 03:27 PM
1.3Litre
Old Aug 12, 2005 | 03:44 PM
zoom44's Avatar
if you are going to be running at that speed alot i would suggest a heavier oil than the 5w20 stock spec. also change tranny and diff lubes.
Old Aug 12, 2005 | 03:51 PM
brightnova's Avatar
Rampage!!! Arghh!!!
Hi zoom. Can you explain why that is? I'm interested in learning the effects of oil on temps the engine runs at. Thx
Old Aug 12, 2005 | 03:56 PM
Mugatu's Avatar
Even My Dog Searches
you just confessed to voiding your warranty. ask abbid.
sorry.
Old Aug 12, 2005 | 04:03 PM
The next run in a couple of weeks will have a 83 mile leg. My temp gauge was pretty solid but, I have been looking for an oil temp gauge since I don't know what that temperture was. Also my cooling fans did not run for very long after a 28 minute run. What about the diff lubes, what is in there stock?
Old Aug 12, 2005 | 04:06 PM
Is there somebody from my dealership here?
Old Aug 12, 2005 | 04:11 PM
wedge357's Avatar
ShinkaMan #748 SV6P
Check this thread...
Old Aug 12, 2005 | 04:28 PM
Sounds like an occupational hazard. I just sued my eye doctor, I' ready for something bigger.
Old Aug 12, 2005 | 07:53 PM
Fanman's Avatar
Go for the RB REVi with the ram air duct to get cooler outside air. For you radiator maybe go back and fill it with a higher percentage of radiator fluid & some of the water wetter, DEI radiator additive stuff. My friend runs it in his stock car racing, said on average it gives them 10 degrees better performance. Should help your long distance racing performance.
I have the Royal Purple transmission gear oil & it has really helped shifting.
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Quiggs321
Sep 30, 2015 05:34 PM
urbanvoodoo
Sep 30, 2015 12:41 AM
drlubell
Sep 26, 2015 11:58 PM
