Sirius Antenna on Shinka
Old Aug 11, 2005 | 09:28 AM
tdb's Avatar
tdb
Does anybody know how Mazda attaches the Sirius XM antenna on the Shinka trunk lid? Considering getting a Shinka model but was wondering if I don't end up subscribing to the xm service can the antenna be removed safely if attached with doubled sided tape. Of course if bolted on then removal wouldn't be an option.
Thanks in advance for any help.
Old Aug 11, 2005 | 09:40 AM
Glyphon's Avatar
脾臓が痛みました
not sure, but i don't think its attached to the trunklid. i believe its someplace inside the car, but like i said, i'm not sure. also, if you get a shinka, it comes with a 1yr subscription to sirius, so i'd be silly to remove it, at least until after that year was up, at least IMO.
Old Aug 11, 2005 | 09:44 AM
jtimbck2's Avatar
Most satellite radio antennas that don't come from the auto manufacturer are magnetic. If I had to guess, I'd say Mazda is using a magnetic antenna.
Old Aug 11, 2005 | 11:35 AM
Tyler8's Avatar
It's attached to the trunk lid, right up against the bottom of the rear window. I don't know how it's attached, but I suspect double-sided tape (it will move a little if you wiggle it).
Someone in another thread explained how to move it INSIDE the car as opposed to being outside. Essentially, detach it from the trunk, reroute the wire inside the car and set the antenna just inside the rear window (so it can still "see" the sattelite).
Tyler8
2005 6MT Shinka
Old Aug 11, 2005 | 12:50 PM
tdb's Avatar
tdb
Thanks very much for the info. Sounds like there are no holes in the trunk lid. Just wanted to know I had the option of taking it off if I don't subscribe after the initial one year period.
Old Aug 11, 2005 | 12:56 PM
Tyler8's Avatar
Originally Posted by tdb
...initial one year period.
Turns out that it's actually a 13 month period for the free sirius. 12 months with the purchase and 1 month free from sirius for being a new subscriber.
Tyler8
2005 6MT Shinka
Old Aug 11, 2005 | 01:57 PM
Zuhalter Vati's Avatar
There are no holes. You can open the trunk and see that it doesn't go through
Old Aug 11, 2005 | 03:07 PM
Tazman's Avatar
Magnetic
From a Shinka owner, the Serious antenna is magnetic.
Old Aug 12, 2005 | 07:31 PM
tiga's Avatar
no need to put it on the truck nor the roof. I have had Sirius on my last two cars and currently have it on my present three cars. Have always had the antenna on the inside rear deck. Works perfect. On my 8 I have it coming up from the rear seat and then placed thru the rear seatbelt guider atop the seat. Just put the wire thru the cutout in the center of the plastic and no need to use sticky tape or anything. If you ever want to take it out, you can with no problem.
Tgiolitto100
Sep 29, 2015 10:52 AM
ErwinN
Sep 23, 2015 09:29 PM
Counter_Glockwise
Sep 21, 2015 06:51 PM
Von Walker
Sep 13, 2015 03:54 PM
Tsurugi
Sep 7, 2015 08:27 PM
