HELP NEEDED sp2 Greddy Exhaust
Old Aug 10, 2005 | 08:52 PM
dova's Avatar
Exclamation HELP NEEDED sp2 Greddy Exhaust
I got my exhaust system Yesterday I'm doing the installation myself I read in this furum is real easy .. I just have some questions ... since no Instructions came in the box...
I have 2 gasket looking things and 2 screws only
Do i use a gasket at each end ?
Do I use some of the srew that where on the oem exhaust?
Pls guide me with this installation...any thing I need to know....
I try searching in the D.I.Y. but I could not find anything...
Old Aug 10, 2005 | 08:57 PM
expo1's Avatar
He's as bad as Can
One Gasket and the 2 screws are for the muffler to pipe connection. The other gasket is extra. On the end that connects to the CAT pipe you re-use the OEM gasket & nuts/ bolts.
Have fun I have the SP2 also
Old Aug 10, 2005 | 08:59 PM
lurch519's Avatar
www.evoperform.com
i believe that the exhaust is in 2 pieces. the muffler section, and the pipe between the cat and the muffler section. one gasket should go between the cat and the pipe, and one between the pipe and the muffler section. the bolts and nuts will connect the pipe and the muffler section together, and you should reuse the factory bolts to connect between the pipe and the cat.
Old Aug 10, 2005 | 10:08 PM
Kel Rx8's Avatar
if your not 1st your last
what the said ^^^^^^^^^^^
but make sure to go to autozone or pepboys to get some bp bolt removal spray
makes life easier . 5x better than wd40
Old Aug 11, 2005 | 07:08 PM
dova's Avatar
thanx guys...Ill post some pictures a.s.a.i.p.i.o.
Old Aug 11, 2005 | 10:02 PM
Roninz's Avatar
Hey guys,
Well i just joined in the forum after installing my sp2 and read about the gasket, ive noticed there was a smooth side and a rough side on it so i thought both smooth side goes together and rough side on the piping, which basically i installed both gasket is this wrong ? i mean does running with both gasket can cause any problem ?
Cheers to all Rx8 owners :D
Old Aug 11, 2005 | 10:28 PM
theCATALYST's Avatar
In darkness I sleep.
Originally Posted by Roninz
Hey guys,
I also have the SP2. Im not sure if if installing both gaskets will cause a problem, you are the first I have heard to actually do that. Turn the car on and see if you can hear an exhuast leak around the gaskets. Otherwise, I guess it should be fine.
UHATEIT
Dec 10, 2015 02:57 PM
Shinka84
Aug 19, 2015 04:55 PM
cschoeps
Aug 6, 2015 12:44 PM
RX7.9
Jul 20, 2015 12:01 PM
