Help wiring subs
Old Jul 31, 2005 | 04:00 PM
buyinan8's Avatar
Muff Driver
Help wiring subs
ok i'm wanting to put two subs in my trunk. I have the box built, the subs in, and i have all of the things necessary to finish the install i think. However, i need wiring diagrams to find the preamp output of the headunit at the bose amp and i'd like to also see what i can find for the easiest remote turn-on hookup. The problem is: I've looked through the DIY forum and done numerous searches and had plenty of results, however all of the pics are now gone from the threads. I'm basically a beginner at wiring all of this aside from watching a few installs, so any tips on any part of the install would help. thanks
Old Jul 31, 2005 | 04:33 PM
staticlag's Avatar
The Professor
the bose has no preamp, you need a line level converter to take the tap from one of the speakers. JL makes a really nice one, or David Navone engineering makes a really clean one also.
tap into the green wire of the lighter plug in the center console. You need to remove the entire center console to get to this.
Old Aug 4, 2005 | 04:24 PM
NiNjA99's Avatar
Former RX8 Owner
when i did my subs, i tapped the rear 6x9's for line converter. i think its easier and you dont have to run RCA's through the whole car. i connected the remote turn on to my fuse box on the drivers side.
tjohnmeyer
Sep 28, 2017 05:03 PM
Danield97
Sep 30, 2015 05:59 PM
Quiggs321
Sep 30, 2015 05:34 PM
jer2911
Sep 29, 2015 06:37 PM
Learners_Permit
Sep 27, 2015 07:38 PM
