View Full Version : 18 inch Stock Rims Info
csaltkill
07-28-2005, 08:31 PM
I am looking at replacing my stock rims. What do I need to know when I am shopping. Like offset and space between the lug nuts?
Thanks.
jaguargod
07-28-2005, 11:37 PM
I am going through the same thing. The size of the factory wheels is 18" x 8", the offset is +50 mm and the bolt pattern is 5 x 114.3 (4.5). I have been told that a wheel as wide as 10" will work, but I am only going to go as wide as 8.5".
TexasKyle
07-30-2005, 10:22 AM
Damn, I thought the stock rim was 7.5 inches....of course I never measured it...thought I got it off this forum. Must be my bad.
The FOG
07-31-2005, 09:45 AM
Does anyone know how much the stock 18's weigh?
Ole Spiff
07-31-2005, 12:41 PM
If I remember right they're about 22 lbs.
Fanman
07-31-2005, 01:07 PM
A bit of debate about this. It is either 22 or 23 lbs.
rotary_never_dies
08-02-2005, 12:46 PM
:confused: Aint the offset different between the front and the rear wheel? I m thinking bout getting the Volk GT-C face 2 What's the offset of the front and th back?
dazygirl415
08-02-2005, 12:59 PM
Be aware that if you go with a bigger than stock rim/tire combo, you may have to roll your fenders to get clearance. I'm currently at 18" x 8.5" and I didn't have to roll but it all just depends.
DreamWarrior
08-04-2005, 04:18 PM
Are the front/rear offsets different? I don't think so....
I think they would be if you had (or decided to put) a different size rim in the front and back; but we don't AFAIK.
ElusiveFX
08-04-2005, 06:26 PM
The offset's on our cars is the same all the way around, that way we can rotate our tires!
If you are going with aftermarket wheels, make sure the offset are set lower than what stock is because the rear wheels, as well as the fronts sit alot farther in than they really need to...
DreamWarrior
08-05-2005, 12:13 PM
How does changing the offset effect the drivetrain? Does it put more stress on the wheel hubs?
connor@tirerack
08-05-2005, 03:35 PM
The OE wheel specs for the factory wheels are listed below:
04 RX8 6speed
18X8 front and rear
5-114mm bolt circle
50mm offset front and rear
67mm center bore
sorry, I don't know the OE wheel weight
04 RX8 automatic
16X7.5
5-114mm bolt circle
67mm center bore
Sorry, I don't know the weight
17" package is the same as the 6 speed OE specs
There are several factors that go into making sure a wheel fits correctly above and beyond the information above. You also need to account for
-Caliper clearance vertically and horizontally
-The X-factor which is the distance from the mounting face of the wheel to the back side of -The X curve Which is the curve on the back of the spoke
-Tolerances for suspension and steering component
-overall diameter and load capacity issues
If you click on the Tire Rack link and enter your exact model in the shop for wheels section you will be able to see all of the wheels that we carry for your car. We also pre figure the fitment specs to save you the guess work.
Friskoaznjock4o9
08-05-2005, 03:45 PM
hey i was wondering if any one had a 19x 7.5 rims on their car..or do anyone know if its ok to go a bit smaller on the wheel width. i want this one rims in particular but they only have it in 19x7.5. so i was wondering if any one has put similar rims on or anyone knows it would be ok.
KYLiquid
08-05-2005, 03:53 PM
remeber a wider wheel/tire doesnt always mean more grip...most of the time you are just changing the SHAPE of the contact patch NOT SIZE!
although most people throw that out the window if they want a certain look or stance to the car.
