Where is the speed sensor located?
Old Jul 26, 2005 | 02:21 PM
donald121's Avatar
I wonder if anyone know where is the speed sensor located. (picture or diagram will be great) I'm looking into how to install an aftermarket dvd navigation, and most units required to connect to speed sensor. Thank you.
Old Jul 26, 2005 | 02:33 PM
KYLiquid's Avatar
Oil Injection
my guess its its reading off the output shaft speed in the transmission.
Old Jul 26, 2005 | 02:44 PM
two rotors's Avatar
As I read it the speed signal comes from either ABS or the DSC Control Module,depending what model you have.Since I do not have wiring diagrams I cannot send a picture showing where to 'tap' in.
Old Jul 27, 2005 | 02:21 AM
staticlag's Avatar
The Professor
https://www.rx8club.com/series-i-interior-audio-electronics-24/speedometer-output-wire-where-51597/
Old Jul 27, 2005 | 12:48 PM
donald121's Avatar
Thanks everyone. I found out more details of where the speed sensor located.
Attached Thumbnails Where is the speed sensor located?-transmissions_1a.jpg   Where is the speed sensor located?-transmissions_2a.jpg   Where is the speed sensor located?-transmissions_3a.jpg   Where is the speed sensor located?-transmissions_4a.jpg   Where is the speed sensor located?-transmissions_5a.jpg
drebbrnator
Dec 27, 2018 07:02 PM
stickmantijuana
10
Oct 27, 2015 04:11 PM
IB Cristina
West RX-8 Forum
Aug 20, 2015 08:52 PM
Nisaja
Aug 6, 2015 01:27 AM
