olddragger
07-18-2005, 06:47 PM
Ok you tech heads. Can someone tell me what is the actual operating temp for this car. In the old days it was around 180F. Is this still true or did they up the temp for emissions reasons etc? I am wondering if a 50-50 ratio of water to antifreeze will work. ANd the ecu/system be reset to run at 170-180 degrees. Dont know how to do that yet but I bet it can be done.
Olddragger
guy321
07-18-2005, 06:49 PM
I think my exhaust temps were like 1200 degrees or something if that helps?
hmm im running 50/50 now shoudl I change something?
Hey dragger, here's a post that may help??
http://www.rx8club.com/showpost.php?p=961853&postcount=65
You are one old dragger! Operating temeratures generally run around 210 now in standard piston engines. I think that the change in temps came somewhere in the back half of the 70's. Ahh, the old days.
PaulieWalnuts
07-18-2005, 11:16 PM
How did you measure that? I'm pretty sure the Renesis exhaust runs about 1600-1800 degrees. Piston engines tun 1000-1200.
He's asking about operating temp anyway.
army_rx8
07-18-2005, 11:21 PM
well accorind to my guages....my oil is around 75 deg C. adn my water ism knjbhvgctf67iujhygtxqs
army_rx8
07-18-2005, 11:22 PM
well accorind to my guages....my oil is around 75 deg C. and my water temp is around 80-100 deg C.
hope that helps (it all depens on the conditions..outside temp...how hard i'm driving. but the thermostat opens at around 80-85 deg. C. (for water.
guy321
07-18-2005, 11:25 PM
It probably was higher.. I was getting that # from memory of the last time i looked at my canscan.
zoomzoom_8
07-18-2005, 11:59 PM
So guy321, where do you have your EGT probe mounted? Got my gauge, got to get it mounted and heard to NOT put it in the exhaust manifold cause it would pin the gauge out but if I put it in pipe before cat then it is not a true indication of the inside engine temp. So where is yours :)
olddragger
07-19-2005, 09:52 PM
yep I guess i have shown my age. Oh well the secret is out and i can get that viagra.
So temp goes up to 212F huh? Well I wonder how high of a percentage of water we can run here in the south. Maybe 70%? Or is this thing controlled too much by the ecu? If we can get the operating temp down 10 degrees and the intake temp down a little then we will see a little performance gain.
olddragger
guy321
07-19-2005, 10:34 PM
Mine comes from CAN data.. I believe it's from the cat.
zoomzoom_8
07-20-2005, 01:26 AM
yea, i have that in hymees program, just wanted to hook up my egt gauge cause i do not have my carputer all together, thats a whole new project, gotta get past this turbo stuff first :)
