NON Bose Amp Install
Old Jul 14, 2005 | 01:33 AM
yocoop's Avatar
OK guys, I cant find exactly what Im looking for in the search. I just got an RX8, are there preamps in the back of the head unit that i can hook my amp up to?? Also is there a sticky anywhere on how to get the Head Unit out to get to the back? Thanks for the help guys im a newb.
-Andrew
Old Jul 14, 2005 | 09:08 AM
Tamas's Avatar
Registered Lunatic
No preamps, just speaker level signal. If you get an amp that can accept this, it is not a problem. That's what I have too.
Regarding removing the head unit, yes, there are threads you can use in the DIY section. One of them was for an Ipod connection, but it has detailed instructions how to remove the head unit.
Old Jul 14, 2005 | 04:47 PM
MrWigggles's Avatar
Originally Posted by djseto
Actually..if you have the Bose head unit, you need to get a differential line converter. If you use the speaker level signal, you are going to get a low voltage signal that is not full bandwidth.
yocoop,
You allcapped "NON" in the title. Try putting it in bold next time as well.
-Mr. Wigggles
Old Jul 15, 2005 | 08:40 AM
VBprogrammer666's Avatar
I have the non-Bose, standard stereo and I added an aftermarket amp that accepts both speaker level and line level inputs. I wanted to go with the line level inputs, so I would have more control on the input level to the amp. So, I bought two speaker to line level converters from crutchfield - here's the link.
http://www.crutchfield.com/S-D8e65Oq...line+converter
Works and sounds great.
Old Feb 22, 2006 | 01:00 AM
brtzrx8's Avatar
Does this mean that if I get an amp with speaker-level inputs , I won't need to use a LOC with the stock stereo system?
Old Feb 22, 2006 | 12:53 PM
forbidden's Avatar
Are you adding a sub or adding front and rear speakers as well? This will tell you the direction you need to go. In all cases you need to use a powered LOC, this was you can set output gains on the unit. So whether it be a simple in line LOC like the Navone piece or the highly advanced multi channel LOC like the Audio Control LC6, either should be used instead of the basic built in LOC's in the amplifiers.
yurcivicsux
192
Sep 12, 2017 10:54 PM
juicemantwon
Sep 26, 2015 12:30 PM
just1jack
Sep 9, 2015 04:45 PM
nivong
Europe For Sale/Wanted
Sep 2, 2015 07:54 AM
