Need Opinions on Subwoofers
Old Jul 10, 2005 | 07:59 PM
shinka213's Avatar
Pettit fangurl <3
Im thinking about getting a subwoofer and was looking at the audiobahn tube unit...comes with built in amp and wiring kit....Ive got the existing 9sp Bose....has anyone done an install with an Audiobahn?
Old Jul 10, 2005 | 08:39 PM
TRU681's Avatar
Heard nothing but bad things about Audiobahn. Their subwoofers hits hard but it seems to break easily because it cheaply built.
Old Jul 11, 2005 | 12:36 AM
forbidden's Avatar
Steer clear. You can do much better. Your car will thank you.
Old Jul 11, 2005 | 07:33 AM
modena's Avatar
Modena
You could go with a infiniti self powered sub,
Heard a couple of those in an 8 and they do not sound bad at all.
Easy to install to
Old Jul 11, 2005 | 08:00 AM
KYLiquid's Avatar
Oil Injection
Easy to install to
if its the infinity 10" basslink sub that your talking about.... thats the way I am going.
Simple to install. sounds good, fairly compact and easy to mount.
my girlfriend has one in her RSX-S, her car had the bose system in it, we replaced the head unit with an Apline, put in all new JL componets with a 4 ch JL amp and then added the Infinity Basslink 10" sub. the car now sounds amazing. the sub (onced tuned for the car with its crossover and cutoff/volume) is the perfect mach.
if your into bass that people can feel outside the car from a block away...this is not the sub for you. if you simply want tight, clean, low end to add to your car...something that will sound at home with 50cent, dave matthews band, sexpistols, gorilaz....anything you can throw at it...then give this sub a listen.
the RSX-S is a hatch back, so anything you throw in the back (with the sub) slides around, and even with cooler banging into it, ect. it has held up well and still looks/functions like new.
I plan to get one for the RX8 in time, just to add a little more bump to the bose.
We found hers new for 180 shipped on eBay
New_Mazda_Guy
NW RX-8 Forum
Sep 19, 2019 11:20 AM
OnebaddRx8
Aug 25, 2019 11:34 PM
Digitz0070
Oct 7, 2015 12:43 PM
Learners_Permit
Sep 27, 2015 07:38 PM
Austin22
Sep 23, 2015 04:46 PM
