Gtec
Old Jul 9, 2005 | 06:38 PM
Gtec
Ok, it was 102 degrees out side.
According to the Gtec I got.
1/4 15.53 sec
And that's with a slow start, no wheel spin. DSC/TCS on.
Gross weight was 3558 lbs.
Two people in car.
Old Jul 12, 2005 | 01:31 PM
RX-Hachi's Avatar
Not a bad result considering everything you stated. But why even bother to do a 1/4 mi. run under such poor conditions?
My best Gtech run was 0-60 in 6.4 secs with a 4k rpm clutch drop. Pretty sure if I got a good launch and got her up to 7k revs (like the car mags did), my time would be around 6 secs flat, maybe better. But I don't feel the need to fry my clutch, so I'm satisfied with 6.4 secs. I did a rolling start on one run and got 0-60 in 7.2 secs. Which still betters Car&Driver's 5-60 in 7.5 secs.
I know many question the accuracy of the Gtech, but for me, it just validates the acceleration potential of my own car.
Old Jul 13, 2005 | 12:13 AM
It was my first opportunity to use a G Tec. So I took advantage of the offer.
I agree and do not like 1/4 mile sprints, but since I just had the car dyno'd I wanted to compare it with G Tec.
Old Jul 13, 2005 | 01:50 AM
spictacula's Avatar
how do u both like Gtec ? should i get a Gtec i was thinking about it? should i invest in one or not?
Old Jul 13, 2005 | 01:09 PM
RX-Hachi's Avatar
I like it for what I use it for, basically a better stop watch. But I really don't use it all that often.
I have the old Gtech-pro, got it years ago, cheap off of ebay. It's suppose to be quite accurate for 0-60 & 1/4 mi., as long as the ground is level, and beats a hand stop watch for sure. The new models allow you to do much more.
Old Jul 13, 2005 | 01:20 PM
WaterLogged's Avatar
I have the newer RR model and got it mainly for the ability to do HP/Torque comparisons from one tune/upgrade to the next. Also the RR allows uploading to a computer as well as a "road racing" mode that allows you to plot out your performance differences for various runs at an auto-x or a day at the track.
Overall I'm pretty happy with it, but to do HP/Torque runs there's a slight learning curve to be consistent with your tests. Once I got that figured out it's accurate from one run to the next. It's DEFINITELY not a replacement to a real dyno or race track timing system.
Old Jul 14, 2005 | 01:08 AM
A lot of people have reported using the G Tec as a support tool for tunning.
Old Jul 14, 2005 | 07:44 AM
rkostolni's Avatar
The new RR is pretty cool. It provides a lot of useful features to help learn launching and shifting. It is also great tool for comparison. I am always changing things on my car, and then going crazy trying to decide if it helped or hindered. With the Gtec, I can be sure if it helped or not.
I'm not sure about its absolute accuracy for 1/4 mile and 0-60, although I suspect it is pretty close, but relatively I believe it to be very accurate and consistent. I haven't used the HP feature enough yet, as I just upgraded from the old Gtech to the new RR model so I haven't used it enough yet to decide if its consistent, but it could definitly be useful if it is.
Old Jul 14, 2005 | 08:24 AM
It's consistent as long as you calibrate it before you start doing your runs and you are on a long, flat road. Fortunately the exit to my neighborhood is perfectly flat so I use it for calibrating, then a nice farm road is not too far away to do the longer runs.
Old Jul 15, 2005 | 04:55 AM
kinda apples and orange, but got a gtimer 2 for bday. have been beeting the hell out of my car since. the last tank of gas was the worst ever. 18.5 mpg.
this is only the 2nd time i have been below 20. anyway i installed the revi intake this evening and made a few more runs.
got the timer down to 14.9 1/4 and 6.45 0 to 60. i am launching at ~6k with feathering the clutch and still getting to much wheelspin. next step to lower rear air pressure.
temp 78 humidity ~85%.
all the reading about the gtech and the gtimer have it within .1 on all times.
