View Full Version : a/c enhancement: Ice32?
beachdog 07-09-2005, 04:33 PM A well respected, local mechanic swears that Ice32 makes a/c colder, reduces the power that the a/c compressor requires and improves gas mileage. It is a lubricant for the refrigerant.
For all the 8's with marginal a/c, might be worth a try. Around here it would cost $75 installed, not sure if it can be purcased for DIY.
Have any of you tried this?
www.ice32.com
swoope 07-10-2005, 02:26 AM here is something else that is supposed to work.
http://www.qwik.com/q_qwikboost.html
and at a much more reasonable price.
http://www.jcwhitney.com/autoparts/Search?catalogId=10101&storeId=10101&sku=81PD7556W&searchbtn.x=11&searchbtn.y=6
DrComputer 07-10-2005, 02:11 PM But the bigger question..... has anyone tried these? Do they work?
swoope 07-11-2005, 02:51 AM search i am sure i found this product on this forum..
beachdog 07-11-2005, 12:15 PM search i am sure i found this product on this forum..
tried searching all the way to the beginning of the forum. 1000's of references to a/c but none to ice 32, ice32, refrigerant lube, refrigerant lubricant, etc... Not a single reference that I can find where somebody has tried this product.
Thanks for the JC Whitney reference. Product had a bunch of accolades but hard to tell if any are legitimate.
swoope 07-11-2005, 05:19 PM i think it would be worth a try as a dyi if you have the gauges. ~ 15 bucks with shipping. i am not really having any problems with my ac, never have, but my car stays in the garage during the day.
+ good tint.
MDRX8 07-13-2005, 12:46 PM Had it installed yesterday. Brought the temp down 4 degrees. It also takes less time for the A/C to put ou cold air. Installed $65 at a Firestone Dealership.
cleoent 07-13-2005, 05:13 PM Had it installed yesterday. Brought the temp down 4 degrees. It also takes less time for the A/C to put ou cold air. Installed $65 at a Firestone Dealership.
so you're saying it's a good deal then eh?
swoope 07-13-2005, 05:14 PM Had it installed yesterday. Brought the temp down 4 degrees. It also takes less time for the A/C to put ou cold air. Installed $65 at a Firestone Dealership.
and you live where??????
swoope 07-13-2005, 09:50 PM http://www.acsource.com/index.asp?PageAction=VIEWPROD&ProdID=453
MDRX8 07-14-2005, 03:41 PM It was a good deal for me since my 8 temp out of the vents ran around 50 degrees. Live in SC........ Now I am down to 46 and it does cool faster.
beachdog 07-15-2005, 08:49 PM http://www.acsource.com/index.asp?PageAction=VIEWPROD&ProdID=453
swoope, you are good with those searches. Did you see the price for the injector? $78. If I was having an A/C problem I would definitely buy it. I might anyway just to see if it really helps the gas mileage. Maybe everyone in Otown wants to get together and have an ice32 installation day?
swoope 07-16-2005, 03:47 AM swoope, you are good with those searches. Did you see the price for the injector? $78. If I was having an A/C problem I would definitely buy it. I might anyway just to see if it really helps the gas mileage. Maybe everyone in Otown wants to get together and have an ice32 installation day?
yea i give good search. if you give me a link for the injector i will see if anyone i know has one. i would be curious to see what would happen if you did the ice 32 + the other. i tend to believe that the other would work better.
let me know. right now it is becoming mod fest on my car.
btw are you having ac issues that are bad, and are you tinted?????
beachdog 07-17-2005, 11:08 PM yea i give good search. if you give me a link for the injector i will see if anyone i know has one. i would be curious to see what would happen if you did the ice 32 + the other. i tend to believe that the other would work better.
The injector was on the same site as the ice32
http://www.acsource.com/index.asp?PageAction=PRODSEARCH&txtSearch=53123&Page=1
Actually, I have never really had an issue with the ac. One time after a long highway run and sitting at a long light it blew warm for a couple of seconds. It bothers me that the compressor cycles so much but it works well enough.
My car is garaged 99% of the time so I have not gone for tint.
Mostly I am curious about the additives for the R134a refrigerant. I get tired of reading all the complaints so I figure doing a test would be constructive.
clydejmuggs 07-17-2005, 11:18 PM What is we set this up for the first week of August?
I have one of these injectors in my tool box. We could use a digital meter for before and after.
swoope 07-18-2005, 12:44 AM What is we set this up for the first week of August?
injectors for one or both??? i am game. total cost for both is 20buck if you have the right tools.
if somebody wants to order 2or 3 of what ever i will cover the other 2 or 3 im thinking the guy with injector rides for free.
this i just my opinion i could be wrong.
the fun thing we could do is the lube vs the freon "helper"
clydejmuggs 07-18-2005, 02:12 AM Sounds good to me..
swoope 07-18-2005, 02:42 AM Sounds good to me..
where are you. one is adding oil the other is freon based. i am sure you know that, but to state the obious is the end of the story.
btw, i will be off work till fri. pm.
beachdog 07-18-2005, 06:52 PM What is we set this up for the first week of August?
I'm up for it.
That's good by me. I think that I'd like to try the lube (ice32) since the local mechanic loves it.
Swoope, you got a preference?
Clyde, if you want to try the ice too, I'll get an order going in the next couple days.
swoope 07-18-2005, 09:01 PM yea im in lets to the ice first. i will go ahead and order the other stuff just for fun. i asumme we will split the cost to cover clydes??
do you think this is the same stuff as the ice 32??? http://www.jcwhitney.com/autoparts/Product/tf-Browse/s-10101/Pr-p_Product.CATENTRY_ID:2002848/showCustom-0/p-2002848/N-111+10201+600002288/c-10101
beachdog pm retruned.
beachdog 07-18-2005, 11:20 PM yea im in lets to the ice first. i will go ahead and order the other stuff just for fun. i asumme we will split the cost to cover clydes??
Hard to tell about the jc whitney stuff since there is absolutely no description.
I will order the ice as soon as I hear back from Clyde. Not sure which one he wanted to try.
This one is probably a competitor to ice
http://www.jcwhitney.com/autoparts/Product/tf-Browse/s-10101/Pr-p_Product.CATENTRY_ID:2002858/showCustom-0/p-2002858/N-111+10201+600002288/c-10101
swoope 07-18-2005, 11:44 PM the reason i came up with the oil is that is mentioned on the ice32 about the molecules. and reading between the line seem to be the same stuff.
i ordered the quikboost. not sure if i am going to get it. doesnt come up on the site, but i was able to find it and get into the cart. will know in a couple of day. ended up being 18 buck. damn shipping.
when it gets here i will toss it in and see what happens.
beachdog 07-19-2005, 12:22 AM Now I am wondering about this. Found an automotive ac forum and the only mention of ice32 was archived from a couple of years ago. No one had tried it and mostly they were making fun of additive products.
http://www.autoacforum.com/searchresults.cfm?FTVAR_KEYWORD1FRM=%20&FTVAR_DATESELFRM=1&Selection=false&FTVAR_AUTHORFRM=&FTVAR_TABLECHOICEFRM=current&FTVAR_CATEGORYIDFRM=2,3,4&FTVAR_SEARCHWHATFRM=t&FTVAR_STARTDATEFR%20&FTVAR_ENDDATEFRM=
swoope 07-19-2005, 12:48 AM hey it not like i bought the turbonator.
we will see.
Razz1 07-19-2005, 12:50 AM All freon cans have lubricant in it.
swoope 07-19-2005, 12:57 AM yes,
i am aware of that, might be some advantages to an improved lubracant. ie dino vs synthetic. not sure, but it is a cheap experement.
clydejmuggs 07-19-2005, 11:08 PM Do I need to bring the digital thermometer?
BTW last time I order a timing belt from J.C. Whitney I got a inner tube for a ten speed bike. They wouldn't fix the problem until I sent the 2 buck inner tube back and payed $1.50 to ship it...
Thats all I got to say about that.... :cool:
swoope 07-19-2005, 11:26 PM Do I need to bring the digital thermometer?
i have ok luck with them order some foam air filter for my bike. i thinking 50 50 on getting the quikcool. not on site anymore, but got an email from them saying it is in stock.
it is an advernture. as to the digi temp gauge, you are in control.
