mazdaspeed fog lamp bracket
Old Jul 8, 2005 | 08:14 AM
johnnyo's Avatar
Defensive Driving: FAILED
going to order the MS front bumper, do i also need to order the fog lamp bracket? my car has the sport pkg btw
Old Jul 8, 2005 | 11:03 AM
adrian-1's Avatar
Ex- member.
yes, you'll need to order the MS brackets.
Old Jul 8, 2005 | 01:10 PM
w0rm's Avatar
PUSHER ROBOT
The fog brackets will be required if you want your fog lamps.
I just got my MS front/rear in and it seems MS has changed it slightly. There's now a black bar that runs across the front vent, covering the 10MPH bumper.
Does anyone have info on this?
Old Jul 8, 2005 | 01:21 PM
Outlaws eXtreme's Avatar
2010 Prius - Miss the 8
That black bar is suppose to be there. It's always been there. If you want to take it off you can, but I think you'll have to change the screen to cover the gap. It's also where you're suppose to drill through, and mount your front plate... blah.
Old Jul 8, 2005 | 08:37 PM
DynamicDookie's Avatar
goodluck, the brackets are a bitch to install correctly. they're also way heavy. wish there was a lighter alternative (the stock bumper had lighter plastic brackets).
Old Jul 9, 2005 | 01:02 PM
RotorManiac's Avatar
Absolute Rotary Madness
if someone doesn't want to install the fog lamps with the MS bumper, will the looks be ok?
I think the fog lamps are useless, I never turn them on... this way I'll save the money for the brackets too
Old Jul 9, 2005 | 06:16 PM
flyboyindy's Avatar
Yeah...it looks great wtihout the fogs .... and a hell of alot easier to install the bumper!
Old Jul 9, 2005 | 06:30 PM
dazygirl415's Avatar
You can only see my fogs when they are lit as they are installed behind the mesh. Looks great to me!
Old Jul 10, 2005 | 01:36 AM
SlowLude's Avatar
I think they're totally worth it! I mean, you already paid for it, so why let it go to waste? They look just as good as without them if you install them properly (ie. cutting the mesh) I was scared to do it, but it took some courage and I'm super happy with the results! Do a search for pics I've posted.
Old Jul 10, 2005 | 04:21 AM
thew's Avatar
Thews8
yes, Cut the Mesh and mount them .. you go tthem use themm..
ANd Flyboy wheres your Fogs ?
vapor2
May 4, 2020 03:53 AM
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
ShellDude
Oct 1, 2015 09:55 PM
