Question: Speaker to Line Level?
Old Jul 6, 2005 | 06:32 PM
gr8jab's Avatar
I just installed a handsfree bluetooth kit, the HF850 from Motorola. It works great! I had no problems at all. However I do need some help.
About the HF850:
It has a dedicated 5W speaker.
It has a mute wire (active low, open collector).
It has no line-level outputs.
About my car:
I've got a PIE aux-in unit for my sat-radio. It works great. I almost never use the AM/FM/CD.
I've built an audio switch, driven by the mute wire from the HF850.
I don't want to pay $100 for the qubit (or whatever it's called).
The idea is to wire the HF850 to the switch, so it automatically changes to the phone when a call comes (someone else did this here, and it worked great for them).
My calculations:
Since the speaker is 5W and 8ohms, that's approx 6V at max power. I'll use a voltage divider to get it to 1V max. That's line level, right?
Speaker:
I know some speakers are driven with differential signals (one wire swings positive while the other swings negative). Others (like headphones or my sat-radio) have a common ground, and are driven single-ended (one wire swings in voltage).
Problem:
I can't determine if the HF850 has differential or single-ended speaker amp.
Neither of the leads is connected to chassis GND, I've checked with a meter. Does this mean they are differential? I think so.
If so, how do I wire them to the line-level PIE input?
Am I being an idiot? Are line-level inputs compatible with differential signals? Should I just connect it and go?
Thanks for any help.
Old Jul 7, 2005 | 12:11 AM
gr8jab's Avatar
OK, after some more research and some scribbling on paper, I think I found a reasonable solution.
The real issue is if the negative speaker wire is driven actively (differential signal), tying it to ground would be a big no-no. The op-amp would be toast.
Simple solution, use a ground loop isolator. The transformer guarantees that no matter what is in the PIE, it won't electrically connected to the HF850.
So I'll use a voltage divider to bring the signal down to line level, and a ground loop isolator to protect the circuits.
Jst4fun
Mar 5, 2021 07:16 PM
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
duworm
Oct 1, 2015 04:57 PM
Learners_Permit
Sep 27, 2015 07:38 PM
