Engine cover
Old Jun 30, 2005 | 09:22 PM
-=Rowdy=-'s Avatar
Engine cover
I hope this wasn't covered before, but I was wondering how much heat that engine cover we have traps it in. I'm not saying that removing it and having the hood right there would make a big difference but I was wondering if anyone removed it to help air out the engine bay area.
Old Jun 30, 2005 | 09:29 PM
Vertigo-1's Avatar
The engine cover actually HELPS keep the heat down. It's meant to direct air over components and to help exhaust the air out those side vents behind the fenders. Somebody did a temperature measure a while back and found that the temperature increased by a few degrees under the hood with the cover off. Personally I doubt it's a life and death difference, as I've installed the Mazdaspeed strut bar and have to leave the cover off. Car hasn't run any differently since.
Old Jun 30, 2005 | 09:54 PM
salituro64's Avatar
I saw a post where someone retrofitted the cover to fit over the MS strut tower.
Old Jun 30, 2005 | 09:57 PM
N8theGr8's Avatar
Disturbed User
Yeah it just requires some sanding with a dremel tool if I remember.
Old Jun 30, 2005 | 10:12 PM
Glyphon's Avatar
脾臓が痛みました
those vents are cooling ducts for the oil coolers, which are in the "scoops" behind the fog lights. are the ducts also open to the interior of the engine bay?
Old Jun 30, 2005 | 10:32 PM
Michael's Avatar
Assuming the specific heat of the plastic cover isn't insanely different from that of carbon fiber, the carbon fiber replacement cover should stay just as functional (air ducting wise) as the plastic piece, right?
Old Jul 1, 2005 | 12:03 AM
truemagellen's Avatar
Attracts tree branches
don't worry about it...no problems CF cover/plastic cover/no cover :D
Old Jul 1, 2005 | 12:35 AM
djmano's Avatar
RX-8 Pilot
i keep the cover off because i can hear more engine noise. i thot it would reduce heat but i guess according to the above post it is functional in cooling down the engine somewhat.
Old Jul 1, 2005 | 10:06 AM
RX-8 friend's Avatar
The side vents in the RX-8 vent the engine compartment. In the 3rd gen RX-7 they were for the oil cooler(s). The RX-8 oil coolers vent underneath the car.
One of the first things I looked at on the car ;-).
The engine cover does help underhood airflow. As it's rather light, I'd leave it on, even though it doesn't make a big difference. It helps hide all the ugly black "stuff" that isn't engine.
Old Jul 1, 2005 | 10:19 AM
ZoomZoomH's Avatar
Mulligan User
so that thing is actually functional huh... well i'll be damned...
Old Jul 2, 2005 | 07:09 AM
salituro64's Avatar
There are vents in the front of the front tire wheel wells. I am assuming this is also helping to vent the oil coolers.
Old Jul 2, 2005 | 07:02 PM
adrian-1's Avatar
Ex- member.
My trimmed engine cover to fit over the MS bar. Notice the turbo piping underneath.
Attached Thumbnails Engine cover-photo_042505_001.jpg   Engine cover-photo_042505_002.jpg
Jesus Martinez
44
May 6, 2025 08:09 AM
vapor2
Nov 3, 2020 03:38 PM
ShadowDragon78
Aug 21, 2015 03:29 PM
ShadowDragon78
Aug 11, 2015 06:42 AM
MolecularConcept
Aug 9, 2015 04:46 AM
