Does my car not make the advertised HP?
Old Jun 28, 2005 | 02:58 PM
dmp's Avatar
dmp
RX8 and a Truk....
My car's missing HP...3000lbs cars with 238hp don't trap at 90mph.
Old Jun 28, 2005 | 03:04 PM
zoom44's Avatar
http://www.ajdesigner.com/phphorsepo...horsepower.php
http://www.dsm.org/tools/calchp.htm
ive tried several others and they all indicate about 170 at the wheels.
Old Jun 28, 2005 | 03:09 PM
guy321's Avatar
Humpin legs and takin nam
I don't think there's any doubt we're only getting 170 - 180ish to the wheels??? With a very few getting 200, i'd like to see thier times. Gearing most likely has alot to do with it, since we essentially have only 5 power gears, right?
Old Jun 28, 2005 | 03:13 PM
dmp's Avatar
dmp
RX8 and a Truk....
My car dyno'd at 186whp....and my best trap was ~91 mph...I weigh 220lbs in clothes...so figure 3300lbs.
figures about right:
weight = 3300 pound = 3300 pound
velocity = 90 mile/hour = 90 mile/hour
Solution:
horsepower (hp) = 187.7560309513 horsepower
or:
velocity = 91 mile/hour = 91 mile/hour
Solution:
horsepower (hp) = 194.08436213992 horsepower
Old Jun 28, 2005 | 03:15 PM
zoom44's Avatar
what was your time and try the second one also
Old Jun 28, 2005 | 03:18 PM
dmp's Avatar
dmp
RX8 and a Truk....
what was your time
15.0 with a 2.5 60ft
second one?
Old Jun 28, 2005 | 04:09 PM
zoom44's Avatar
second one?
i edited my post to include a second calc link. the hp calcs indicate you are putting 194 whp on the strip or 8 more than on the dyno of 186.
194whp * 1.20(for 20% drivetrain loss)= 232.8bhp which is just 3% off the advertised 238bhp. whats the isue?
Old Jun 28, 2005 | 04:12 PM
124Spider's Avatar
i edited my post the hp calcs indicate you are putting 194 whp on the strip or about 8 more than on the dyno.
194whp * 1.20= 232.8bhp which is just 3% off the advertised 238bhp. whats the isue?
Oh, heck, I can answer that for dmp. :D At the same place and morning as he dyno'd his car at 186hp (uncorrected), mine did 219 (uncorrected; 210 corrected), and my car is rated at 240hp. Something's not quite consistent there.
Old Jun 28, 2005 | 04:16 PM
zoom44's Avatar
that would be the dyno not being consistent.
he said his car cant be putting out advertise dhp based on the reult of his 1/4 mile run - specifically trap speed. however if you actually usea a trap speed to hp calc you get teh numbers about which shows his original remark was incorrect.
Old Jun 28, 2005 | 04:17 PM
dmp's Avatar
dmp
RX8 and a Truk....
The issue is "online calculators are crap" when it comes to the real world.
186hp or even 190hp is still too low, and your 'drive train loss' percentage is too high.
With Miatas using similar (the same?) transmission, but a non-CF driveline, and sending the power to a similar rear-end, they are losing about 26hp...
I simply cannot buy an RX8's drivetrain consumes TWICE that power.
As an aside- the link I went to was estimating ENGINE HP
This method uses the speed or velocity at the end of a quarter mile run. It is used to give an estimate of vehicle(car, truck, motorcycle) engine horsepower. Weight should include the mass of the vehicle, driver and passenger.
...not WHEEL HP...so, even on the run I hit 91mph, that still shows less than 200 'engine' hp...or, about 40 too few.
Old Jun 28, 2005 | 04:22 PM
dmp's Avatar
dmp
RX8 and a Truk....
and from your 2nd link:
Please don't make the mistake of quoting these numbers as if they meant anything
I trust what a dyno showed as mid 180hp for FIVE Rx8s in one day, only hours apart, over what an online-calculator suggests.
For a comparison, I entered the data from my old Probe GT - I went 13.8 at 107 mph...shows:
Using the Speed method, I come up with 296 "on-the-pavement horsepower"
My dyno was actually 242hp.
But for my Miata, which went 16.5@81mph, it shows:
Using the Speed method, I come up with 104 horsepower.
The car dyno'd at 100.2hp...
Talk about inconsistancies...
:D
Old Jun 28, 2005 | 04:24 PM
124Spider's Avatar
Warning: Thread hijack in progress....
No, actually the dyno was very consistent. All the RX-8s but one were within a couple of hp of each other.
Does anyone really think that the RX-8 puts out 238hp at the crank, stock?
Old Jun 28, 2005 | 04:27 PM
zoom44's Avatar
yes but the wording is wrong- why else would the other calc(s)s say at the wheel. "There are two simple horsepower formulas that can estimate the on-the-pavement horsepower for a given car". it cant calculate bhp without knowing the gearing.
second 20% drive train loss is what we have.
check these - all are calulating rear wheel hp and get the same numbers as the first
http://www.amaprostar.com/dynos.asp
http://www.ultimateresourceguides.co...nt/index4.html
http://www.smokemup.com/auto_math/trapspeed_lbs_hp.php
try this one and read it carefully- gives 2 answers 1 whp and 1 bhp by adjusting with 25% drivetrain loss
http://www.gordon-glasgow.org/hpcalc.html
Speed-ER doc's Avatar
yes, I bite
I wish I could donate some horsepower to my underpowered friends.
I've got plenty to spare, and I'm going through back tires too quickly. :p
Old Jun 28, 2005 | 04:33 PM
dmp's Avatar
dmp
RX8 and a Truk....
There's no way the car loses 20% if a Miata loses 15% +/-...it's hard to use a percent, because it's not really a percentage...it's generally a fixed number AND some percent...
still...same engine as a miata, better drive shaft than a miata, similar rear-end as a miata does not mean that much greater loss.
Old Jun 28, 2005 | 04:36 PM
dmp's Avatar
dmp
RX8 and a Truk....
...if Mustangs weren't so ugly...
(sigh).
:p
Old Jun 28, 2005 | 04:38 PM
zoom44's Avatar
how else do we verify the accuracy of his statement?
dmp said there is no way his car traps at 90(1) while providing the advertised hp.what math formula should we use? these calcs are using the math that everyone used before to show that the cars werent making 247. the statement on the one calc site is so you dont sue them. the math is the math.
really dynos are consistent? then why was one car's results so drastically different? dmp says "talk about inconsistencies" but his reults show a car that put down significantly less HP on the dyno then the calc says it should have (problem with car on the dyno see article about bimmers and dynos) and the miata being very close on the dyno to what the calc says it should have- math isnt inconsistent so its got to be the cars onthe dyno that are.
it doesnt matter what anyone "thinks" its what tehy can show/prove- the math shows that at least dmp's car puts out within the legal 5% window of advertised power
Old Jun 28, 2005 | 04:39 PM
dmp's Avatar
dmp
RX8 and a Truk....
side note: Zoom - on your last link, use:
3300lbs, 15.34 and 91mph
My 15.0 run had a 90mph trap.
187hp - so about the same as my dyno day, no? I still hotly debate the car would lose 25% of it's engine power thru the drivetrain. What did FD's lose? I think stocker FD's dyno around 225whp....Much less than 20% loss there, imo.
zoom44's Avatar
im going to split this out of this thread.
Old Jun 28, 2005 | 04:49 PM
dmp's Avatar
dmp
RX8 and a Truk....
But the math has nothing to do with real-world, hence all the disclaimers on those sites.
Actually, those calculators tend to support what my dyno findings were - however measured HP is more reliable than math-conversion online.
Except it does not. (shrug)...and 80% of RX8 owners are in the same boat i am.
[edit - 90%? 95%?]
Old Jun 28, 2005 | 05:09 PM
zoom44's Avatar
really ? math has nothing to do with real world? thats ridiculous.
so when the car came out at 247 hp and people used the formula for deriving whp from trap speed and ET to show the car was not making the advertised power. you cannot now say that the formulas are wrong because you dont like the out come
Old Jun 28, 2005 | 05:21 PM
dmp's Avatar
dmp
RX8 and a Truk....
I'm saying read the sites you linked to. Every one says "Don't take this stuff as gospel".
Here are some facts:
Racing Beat got 216hp with a Renesis on an Engine Dyno.
My car dyno'd at 186whp (~15% drivetrain loss is more reasonable)
A very similiar car loses nearly ALWAYS 25-26HP from crank to engine, verified again and again. (miata).
My car hit a trap speed of 91mph, on my fastest (but not quickest in terms of ET) run
My car weigh, with me in it: car wieghs 3040, in race trim (3/4 tank gas, two 10" subs in large enclosure) + me at 215lbs, clothed for a total of 3255lbs..
You're implying drivetrain losses worse than most any car i've known...I think it's easier to believe Mazda doesn't really know how much power the RX8 makes; or knows, but isnt concerned enough about it do to anything.
You think the car loses 20% of it's power from it's flywheel to the rear tires. I say 15%. Let's meet in the middle, and say 17%.
186whp (even confirmed by what i consider inaccurate online calculators, and what you say is an inaccurate dyno) / .83 = 224hp
Old Jun 28, 2005 | 05:28 PM
zoom44's Avatar
they say dont take this as gospel because their legal people told them to put a disclaimer on the site. but the formula has been accepted as correct since the 50s or early 60s.
5% off of 238 is 226 and since Mazda is firm about it now being within 5% your drivetrain percentage must be wrong.
i cannot account for racing beats dyno but then i have never seen it or the plot from that dyno or any subsequent runs they may have made. but 15% off of 216 is 183 hp. so clearly Mazda is using more of a percentage than you are.
Old Jun 28, 2005 | 05:38 PM
dmp's Avatar
dmp
RX8 and a Truk....
Good reading: http://forum.miata.net/cgi-bin/ultim...c;f=1;t=013972
I don't know any scientists. I know racers. I know 'car guys' and 'drivers'. Those neat caculators are to give ball-park figures - as I showed, they can vary wildly in their accuracy.
...and since my car made 186hp, as measured on a dyno (less if I use the 'SAE number), that number by RB of 216 looks about right - and lends to significantly less than 20% drivetrain loss.
Old Jun 28, 2005 | 05:59 PM
zoom44's Avatar
car guys and racers are the ones that say this formula is accurate!!
another thought- your trap speed. others have hit 94 or 95 mph in stock 8s and road and track tested it at
0–1320 ft (1/4 mile) 14.5 sec @ 95.6 mph
http://www.roadandtrack.com/article....&page_number=1
so maybe its your trap speed that is the problem
