View Full Version : how bad is it to hold at redline
Matt RX8
06-27-2005, 01:13 PM
How bad is it on the engine to hold the RPMs at redline?
Let's say that you are on a track where there are some relatively short straightaways and by the time you get ready to shift from 3 to 4 (at around 90-92 mph) you are getting close to running out of real estate because you need to brake for the next turn. Rather than do the 3-4 upshift and then heel toe back to third while braking for the turn, it is sometimes easier (and quicker) to maintain throttle at 9000 rpm in third and just hold there for a 2-3 seconds.
Is this OK on the engine to maintain revs at 9K RPMS for a few seconds?
BlueRenesis82
06-27-2005, 01:16 PM
No problems. Actually it would help to get any carbon deposits out of the housing, plus redline technically is 9500 or so. I've personally been up to 10k
Matt RX8
06-27-2005, 01:20 PM
Does the rev limiter work with the clutch depressed? Is it possible to over rev while doing a single clutch heel and toe downshift from 4-3?
I've also heard that the renesis doesn't really have a true redline, just a point of deminishing power return from the engine.
StewC625
06-27-2005, 02:14 PM
When I autocross mine, on a particularly fast set up, I was bouncing off the rev limiter for the last 100-200 yards or so of the straightaway. No worries. Also the rev limiter does work in neutral and clutch in.
Nubo
06-27-2005, 03:16 PM
Computer cuts fuel at 9500 or so. You can't overrev with the gas pedal. But of course you can overrev by downshifting.
apotocki
06-27-2005, 04:00 PM
Not to change the subject, but, speaking of 'heel and toe', did anyone watch the NASCAR race yesterday?
FOX had an in-car camera pointing at Boris Said's feet. Numerous times during the race they showed his heel-toe technique.......truly amazing in my opinion as I've 'attempted' this and failed miserably. They also showed multiple screens showing a view out the windshield along with him footwork so you could see the corners coming and anticipate the heel-toe.
ZoomZoomH
06-27-2005, 04:18 PM
if you're not expecting additional time shaved off by upshifting before the braking zone, then holding it at 9k before entering a turn would seem logical in the grand scheme of things, the time you saved from the extra downshift will probably cover the extra tenths of seconds you gain if you upshifted. Wouldn't know for sure unless you set up timing devices for lapping sessions of course, timing equipments do not lie ;)
the 8's pedals are perfectly spaced for heel-toe, FYI :D
so learn how to do it!
L8APEX
06-27-2005, 04:36 PM
When we drive up in the mountains around north georgia, we routinely hold at 8500 or close to 9000, rather than shifting. It is good to know that I am not killing the car. I have been told that the engine can handle a little more, it is the rest of the moving parts that have difficutly with the high rpm's, such as drive belts, a/c compressors and the like. I wish I could learn heel-n-toe, but my size 13's don't cooperate.
pritch
06-27-2005, 04:49 PM
yes i seen the race he was really good at it.
sea-rx8
06-27-2005, 04:59 PM
with my size 12's I can heel-n-toe fine........just give it some practice:D
MI_FamilyMan
06-27-2005, 05:42 PM
I don't think in the instance you describe that there would be any damage done to the engine. I've been practicing the heel-and-toe a bit ever since I realized how much it would help on the track. Man, it is pretty hard!
This may be a stupid question, but when you are in neutral and the clutch is fully depressed or even halfway depressed, is it bad on the clutch to hit the gas pedal (ie. rev it up)? I wasn't sure if you were supposed to let off the clutch completely when you rev-match or double-clutch.
Matt RX8
06-27-2005, 05:51 PM
Heel and Toe is easy with the RX-8. I single clutch heel and toe rather than double clutch. I just became proficient recently and this was the first time I used it on a race track.
The corner in question where I was deciding to upshift was the most dangerous corner on the track (the other 10 corners were quite open). Turn 11 is surrounded by concrete and guard rails so as David Hobbs would say I "decided that discretion was the better part of valour."
Most of the time I had cars in front of me that I could not pass in the corner (since this was a school not a race) so I could basically hold in 3rd gear at about 92mph or so for a few seconds and then brake later than the other cars and end up right on their six anyway. Then I watched them pull away on the straights because they had more hp and torque :( .
MI_FamilyMan
06-27-2005, 05:56 PM
So when you say single clutch, do you mean:
1. Hit the brakes
2. Clutch in, shift to neutral
3. Hit the throttle (still on the brakes)
4. Shift to lower gear
5. Clutch out, back on the gas
Is that how you do it? I haven't tried it in a track setting, but I tend to let up on the clutch a little when I hit the throttle. I guess without practice it all seems to happen so quickly. I also find my foot is not wide enough to hit both pedals by rolling my foot, so I end up having to put my foot up high on the brake pedal and come down hard with my foot (heel) in order to get sufficient revs.
If I'm totally doing this wrong, somebody please let me know...
Matt RX8
06-27-2005, 06:54 PM
1. Hit the brakes
I'll start by saying that I am no expert but I understand it to by like this:
Normally with the double clutch it's
1. brake in and held whole time
2. press clutch pedal down
3. shift to neutral
4. clutch pedal up
5. blip throttle
6. clutch pedal in
7. down shift
8. clutch up
9. release pedal clutch
The key with the double clutch method is that the blip of the throttle is done in neutral with the clutch up. This speeds up both engine and part of the gearbox and is necessary for vehicles without synchros like racecars and old dump trucks. In the long run it will save wear and tear on the clutch.
In newer cars, you really don't need to doubleclutch because you can rev the engine and the synchros will still allow the shift.
Single clutch method is
2. clutch pedal in
3. blip throttle
4. downshift
5. clutch pedal out
MI_FamilyMan
06-27-2005, 08:17 PM
Right. That's exactly what I figured. The only thing is that I was wondering if it was bad for the clutch to be on the gas while the clutch is fully in, or even halfway in for that matter (while in neutral, of course).
-=Rowdy=-
06-27-2005, 08:55 PM
You guys are making my brain hurt.
Matt RX8
06-27-2005, 10:11 PM
LOL
Xyntax
06-28-2005, 12:25 PM
You mean "You were granny shifting when you should be double-clutching" in Vin Diesel's RX-7 was phony? :D :D :D :D :D
I do double-clutching just for the fun of it. But to really get going quick, single clutch does the job. I've been so used to it that I don't even have to look at the tach anymore :)
mzrx
06-28-2005, 07:34 PM
I think you are missing one step, I added in red. That is what I was told don't quote me on it, I am not an expert on it . In double clutching you have to be quick and accurate to pull it off smoothly. It sure fun when you pull it off, just don't practice on a crowded street. Safety first :D
3. shift to neutral
4. clutch pedal up
5. blip throttle
6. clutch pedal in
6.5 blip throttle again
7. down shift
8. clutch up
2. clutch pedal in
3. blip throttle
4. downshift
5. clutch pedal out
:D
lucifuge
06-28-2005, 09:16 PM
interesting that no one has mentioned excessive seal wear at 9000 rpm and beyond.....
rx8pilot
06-28-2005, 09:26 PM
do you have some kind of fuel cut-off mod that non of the rest of us have? (in a sarcastic tone)... if you do let us know where you got it and how much. otherwise..don't post b.s. when we all know what the rev cutoff is.
sorry..in a bad mood tonight. lol
UnstoppableDrew
06-29-2005, 08:38 AM
I used to have an '85 Rx7 with a bad 2-3 syncro. You couldn't downshift into 2nd without rev matching, so I got in the habit of not even using the clutch. I'd just come hot into corners, left foot brake, downshift without clutching and jump on it. That same car in an autocross, being driven by a firend, was accidently shift 2->1 instead of the intended 2->3. Buzzed it up to around 12K RPM, but didn't do it any harm.
I pick up my brand new 8 this afternoon (silver GT), can't wait !
tuj
06-29-2005, 09:12 AM
If you haven't tried double-clutching, give it a go. It makes down-shifting much smoother than a single-clutch rev-match technique, and its more forgiving of being a bit off on the revs. With the double-clutch method, you can rev slighly higher than you will be in the lower gear and still be very smooth, whereas with the single-clutch technique, you must be slower with the clutch release if you are off on the revs a little bit.
Try both (without doing heel-toe) and see which one feels smoother to you. Then, try doing it while heel-toe'ing. I used to use the single-clutch method for all my downshifts (including heel-toe) but I've found the double-clutch method to be so much smoother that I use that now for almost all my downshifts (including heel-toe). The only time I don't double-clutch is if the braking zone is short and there is not enough time to press the clutch twice.
Remember, the whole point of rev matching is to be smooth, and the whole point of heel-toe is to accomplish rev-matching while braking. Therefore, if you can feel any change or distruption in the chassis while you heel-toe, you aren't being smooth.
Some people will say that double-clutching is stupid on a modern trans with syncros. However, the syncros are responsible for spinning the layshaft of the transmission up to the same speed as the driveshaft. If you're rev's are off (too high or too low), when you connect the engine back to the layshaft by releasing the clutch, the car will lurch.
If you use the double-clutch technique, both the engine and layshaft spin at the same speed when you rev the engine (because the shifter is in neutral and the clutch released). Then, when you move the shifter into the lower gear, you can feel it slip in when the layshaft and driveshaft speeds match. This is why you can rev slighly higher than necessary and still be smooth. By waiting for the shifter to slip nicely into gear, you are letting the layshaft spin down to the same speed as the driveshaft. And since you spun up the layshaft with the engine, the speed of the engine is still about the same as the layshaft, so when you let out the clutch, everything is smooth. I should mention that this whole process takes only about as long as it takes to pump the clutch twice once you master it.
ZoomZoomH
06-29-2005, 09:17 AM
i think you just lost them with that dissertation :D
r0tor
06-29-2005, 10:08 AM
are people actually using their heel and toe? I find it much much easier to hit the brake with my big toe and roll on the gas with my small toe... the traditional way doesn't work at all for me - my long legs don't bend like that while still clearing the steering wheel.
oh and I do the single clutch method - i'm smooth with it and i find it much easier and quicker to pull off.
ZoomZoomH
06-29-2005, 10:15 AM
how to implement heel-toe technique varies greatly from person to person, as each person have different foot size and different levels of foot/eye coordination :D
i use the 'ball of foot on brake, blip throttle with side of foot/heel' technique, my foot's not wide enough to cover both pedals with just my toes :o
tuj
06-29-2005, 10:16 AM
Not that many people actually use their heel since you have to have good flexibility and/or get your right knee under the wheel. I use the outside edge of my foot, about halfway back from my toes. I put my toe up near the top of the brake pedal, and roll my shoe up over the top of the pedal a little bit.
Matt RX8
06-29-2005, 11:09 AM
How many blips of the throttle in the double clutch method? 2 or 1?
(see the discussion above)
Do some people double clutch on upshifts? Why? That seems silly with today's cars.
tuj
06-29-2005, 11:19 AM
Double-clutching you still only blip the throttle once. The difference is that you do it with the clutch released and the shifter in neutral rather than doing it with the clutch in.
Double-clutching was used on upshifts in semis and non-syncro cars. Instead of bliping the throttle in neutral, you would wait for the revs to drop so you could engage the next gear. No real point to doing that nowdays on upshifts. Syncros are good at slowing things down, but they are not as good at speeding things up.
Rotary Rasp
06-29-2005, 11:50 AM
sorry..in a bad mood tonight. lolMy rev limiter is set at 9500 also. He is not b.s.ing you, some of us got lucky.
(I can hit 95-96 mph in 3rd gear)
Matt RX8
06-29-2005, 12:50 PM
so is this correct then for the heel and toe doubleclutch downshift?
3. shift to neutral
4. clutch pedal up
5. blip throttle
6. clutch pedal in
7. down shift
8. clutch up
9. release brake pedal
Xyntax
06-29-2005, 02:18 PM
My waterpump was leaking (w/o my knowledge) and dealership replaced it under warranty. Service told me that it's not Mazda's fault, it's two things:
1. Waterpump (3rd party manufactured) wasn't very strong.
2. Engine that runs up to 9,000 rpms puts so much stress on the waterpump no matter how strong the waterpump could be.
I happen to blip to 9K almost at least twice a day. He didn't tell me not to spin it that hard, but he just told me to watch out for leaks so they may repair it quickly before problems come up.
tuj
06-29-2005, 02:31 PM
One thing that's easy to forget with rotaries; the rotors are actually only rotating at 1/3 of the e-shaft speed.
tuj
06-29-2005, 02:37 PM
3. shift to neutral
4. clutch pedal up
5. blip throttle
6. clutch pedal in
7. down shift
8. clutch up
You got it. Extra points if you dive into the corner and pass someone while you're doing it. :) Also, depending on how much you love your transmission, the whole thing can actually be done without using the clutch at all, but I wouldn't recommend it.
BlueRenesis82
06-29-2005, 04:06 PM
I thought you were supposed to keep the car in gear?
Dragonrider
06-29-2005, 05:22 PM
Mine is also set at 9500. :)
knight7
06-30-2005, 06:03 AM
actually if you keep your car at redline and something breaksdown, Mazda mostlikely to tell you you been abusing the car and basically kill your warranty. you are not supposed to drive the car like a sports car, drive it like you got a van or a mazda 6 piece of junk.
r0tor
06-30-2005, 07:28 AM
The real rpms are only 9000 when you are seeing 9500 rpm... the tach lies a bit
Matt RX8
06-30-2005, 09:17 AM
Good, in that case, I haven't been abusing my car at all so Mazda won't be upset with me for driving it like a sportscar. I've been shifting a 9000 on the tach and my fuel cut-off is 9500 so I must be granny shifting each time. No worries with my warranty. :cool:
neit_jnf
06-30-2005, 09:41 AM
the PCM logs data like engine rpm and vehicle speed...
Mikelikes2drive
06-30-2005, 11:40 AM
^^^ even if u reset it by using the brake tapping method?
BlueRenesis82
06-30-2005, 12:36 PM
or if worse comes to worse you could just unhook the battery and clear the PCM. At least I think thats how it works
