Help with engine codes
Old Jun 24, 2005 | 01:59 PM
smrx8's Avatar
Ok hooked up the scanylaser from hymee and got the codes that are causing the engine light.Let me start by saying i have pullies ,high flow cat. racing beat intake,EXHAUST.
1. P2270 Rear HO2S signal stuck lean ON 2 HO2S ´ (See DTC P2270 )
2. P2096 TARGET A/F FEEDBACK SYSTEM TOO LEAN ON 2 FUEL SYSTEM
Then the hymee scanylyser says pending codes
p0302 and p2270
anyone have any ideas ??????????????????????
Old Jun 24, 2005 | 02:10 PM
zoom44's Avatar
https://www.rx8club.com/series-i-tech-garage-22/rx-8-technical-info-cel-codes-pcm-pin-list-collision-guide-26291/
you are running too lean. the 302 code is misfire. it counts the misfire and when it gets over a threshold number lights the cel. reset your pcm make sure the intake is in there tight with no leaks.
xAgyex
Jun 3, 2026 03:47 PM
vapor2
Nov 3, 2020 03:38 PM
Rx808BI
Aug 9, 2015 10:06 AM
Ajmurphy85
Jul 30, 2015 07:51 AM
netrovers
Jul 20, 2015 03:32 AM
