Can i flash my japanese nav into english
Old Jun 21, 2005 | 10:48 AM
MintyFresh's Avatar
i've got an imported japanese type s with dvd nav in japanese. It seems to have a bunch of other menus apart from the nav and tv. Can i flash the unit into english?
Old Jun 21, 2005 | 03:18 PM
MintyFresh's Avatar
well the Type S is basically the 6mt but you dont get the same packages as in the usa. DSC, A/C are standard leather isnt nor is 6CD apparently as i had to get them to nick it from one that had it, for some reason however it did come w/ the DVD nav (possibly bcs its an ex demo) with a map of japan in it , and apparently i can convert it to a normal dvd player if i leave it for a couple of days with the shop. It doesnt have the beepy change gear thing but unfortunately it does have a really annoying limiter which kicks in at 187 kph (still havent found a cure)
but i digress. Can it be flashed?!
Old Jun 22, 2005 | 10:53 AM
Rotary Rasp's Avatar
503wtq Boosted Bimmer
I would think it can be flashed.
Old Jun 22, 2005 | 04:36 PM
mazradiodoc's Avatar
Im sure it could be flashed - but what will you use as a map?
I assume the only map you have is for Japan.
Old Oct 1, 2005 | 06:37 PM
MintyFresh's Avatar
maps aside, there seems to be a bunch of other menus to do with the car itself
Old Oct 6, 2005 | 05:41 PM
Yaboya's Avatar
Got same problem myself. I'm in Ireland and I imported Type S from Jap. Got Japanese nav and tv. What do you mean by "flashed"? Do I have to change the dvd player?
Old Oct 7, 2005 | 03:27 PM
MintyFresh's Avatar
Flash means changing/updating the software of the nav into english.
It wont be the dvd itself that would need changing as thats just for reading the dvd's, there's a board somewhere i guess, maybe part of the HU.
Old Oct 7, 2005 | 03:37 PM
MintyFresh's Avatar
BTW Yaboya have you tried simply using the UK spec dvd, can't see why it wouldnt work. Maybe you can borrow one before buying one from http://www.navteq.com/
Old Apr 5, 2011 | 11:46 AM
yanjagi's Avatar
I have been desperately trying to get an answer to this for the longest time. Did you manage mintyfresh?
ShellDude
Oct 1, 2015 09:55 PM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
FubarI33t
Sep 28, 2015 08:45 PM
Forevermore
Sep 20, 2015 01:04 PM
