oil or water temp gauge
Old Jun 16, 2005 | 08:24 PM
rkostolni's Avatar
I am ordering some gauges and wanted to get an opinion.
I am ordering boost, oil pressure and either oil temp or water temp.
Which is the better indicator of engine temp, water or oil? It seems to me that water is the better indicator, if so what is the benefit of monitoring oil temp over water then?
Also, I assume that the gauges will come with some instructions that hopefully I can figure out the details from there, but to help shed some light any suggested mounting locations for the sensors would be great!
Thanks,
Ryan
Old Jun 16, 2005 | 08:56 PM
v300's Avatar
Why not EGT?
Old Jun 16, 2005 | 09:04 PM
PUR NRG's Avatar
If you had to choose, I'd go with oil temp 'cause you always have the stock water temp gauge to tell you if things are getting bad.
The Defi gauges look very pretty but functionality won out over looks when I bought gauges. http://www.spatechnique.com/dualgauges/dual1.htm
________
Hotbrunette
Old Jun 16, 2005 | 09:08 PM
StealthTL's Avatar
Metatron
Choices.......
I would really want an EGT with any FI gauge set. Especially on a rotary - with boost, you will need one that goes to 2000F!
Only the good gauge makers have models that will 'take the heat.'
S
...you DO already have a gauge for 'BLING', right? :D
Old Jun 16, 2005 | 09:09 PM
rkostolni's Avatar
But the stock water temp gauge is really just a dummy light and doesn't tell you much.
I don't see too much benefit of a EGT temp gauge right now since I don't plan on putting my car on a dyno until I get a boost controller which isn't going to be for a while. An EGT gauge by itself without calibrating it on a dyno isn't very useful, at least not from my understanding.
Old Jun 16, 2005 | 09:19 PM
therm8's Avatar
Bummed, but bring on OU!
EGT guages are too susceptible to location, in my opinion. Given the choice between an EGT and a WB O2, i'd take the WB. As for oil or water, i'd probably choose water, as it is the actual cooling medium. If the engine is too hot, the water will be too hot.
Old Jun 16, 2005 | 09:23 PM
zoomzoom_8's Avatar
Mazda Maniac told me on here the best place to mount the sensor for an EGT gauge is near the secondary 02 sensor on the cat pipe. So that is where mine is going.
Old Jun 16, 2005 | 10:27 PM
PUR NRG's Avatar
What's your definition of "dummy light"? The stock water temp gauge tells you when the engine is too cold, within normal operating temp range and too hot. That is not a dummy light and tells you a lot more than the non-existent stock oil temp gauge.
________
TELEVISION SHOW FORUM
Old Jun 16, 2005 | 10:47 PM
StealthTL's Avatar
Metatron
Oil.......
You are probably thinking of the oil pressure 'dummy light'.
The water temp gauge works fine, and will pin right out when your fan breaks! (ask me how I know!)
S
Old Jun 17, 2005 | 08:08 AM
rkostolni's Avatar
You know you're right, I was thinking about the oil press gauge being the dummy light. So is there a big advantage to having both water and oil temp? Can the oil temp be estimated from the water temp? It seems like they should be very related!
Old Jun 17, 2005 | 10:29 AM
PUR NRG's Avatar
Sure they're related--except for the bit where the turbo is cooled by oil, not water. That's why you want an oil temp gauge to begin with.
________
Wendie 99
Old Jun 17, 2005 | 10:49 AM
RX-8fan01's Avatar
i would recomened a WB 02 gauge ..... seems to be most helpfull with FI cars ... PLus we are rotary ... so i would get that first .... and it prolly the most expensive so get that one first and for the oil and water temp get the oil temp cuz oil coles the turbo more important then water if you ask me ... Just like PUR NRG said
Shane
Jesus Martinez
44
May 6, 2025 08:09 AM
escapedan
RX-8 Racing
58
Feb 10, 2020 06:11 PM
Silver_Excalibur
23
Jun 6, 2019 07:23 PM
wayloco
Sep 1, 2015 09:03 PM
talonhart2
Aug 26, 2015 04:14 PM
