Found Another Secret NAV Menu
Old Jun 13, 2005 | 03:31 AM
redjetpack's Avatar
yup, i have old HU software (9.50) and a PIE installed...... needless to say it doesnt work. all it does is play for 30 seconds, then the HU shuts off, and if the NAV is open it shows the menu you were talking about. i had a thread about it somewhere in here, but i didnt manage to play with it too much.
Old Jun 13, 2005 | 02:15 PM
Rotary Rasp's Avatar
503wtq Boosted Bimmer
I bet there is a way to get to that screen without having the PIE input.
Old Jun 13, 2005 | 03:02 PM
iGash's Avatar
how to check the version oft the headuniT?
Old Jun 21, 2005 | 03:42 PM
MintyFresh's Avatar
To check the HU version
1. turn on the radio
2. hold down the text/audio button
3. then hold the preset no. 1 button
it will show the version. There is a thread somewhere which explains whic flash coresponds towhich year.
<<snip
Interestingly if you have the car turned off then hold down the text/audio + preset no.1 then turn the key to on position (without starting the engine) it will flash CLEAR I have no idea what it clears though.>>
<<EDIT
holding the text/audio will make it flash clear - likely to be all the presets>>
Old Jul 9, 2005 | 06:40 PM
valpac's Avatar
Ahead of its time
Originally Posted by djseto
... the NAV screen went to some Japanese menu. In the corner it showed what appeared to be the input name, which read "TV1", but the rest was Japanese. I tried to play around, but the joystick doesnt work unless you hit "Menu" in which case it brings up a menu, in english, that allows you to adjust the brightness and contrast of the display and also allows you to turn off the Night/Day option which is what changes the background when you turn your headlights on and off. ...
I just had Sirius installed in my car. I get the same screen when I turn off the SAT radio. Weird.
Old Jul 11, 2005 | 09:12 AM
SAFD1450's Avatar
RX-8 Powered Army of One
This is odd. Can someone translate the japanese?
Old Nov 2, 2005 | 11:39 AM
lshu's Avatar
Driving makes me :)
Bump... I just discovered this screen yesterday when turning off the head unit on EX1 (for my dension ice>link) while nav is up. Also tried to play around but only the menu button works as described in the first post. From "TV1", it seems like there is an input for air signals or video? There is also a button at the bottom right corner that says "Auto-M", but I can't find out how to select it. Anyone know the japanese too?
Old Nov 2, 2005 | 04:34 PM
truemagellen's Avatar
Attracts tree branches
There is a TV tuner option for Japanese cars...some of the software to control the channels is already built in
You could order one but it would cost an arm and a leg and they don't broadcast in the same frequencies as us
There was a HUGE thread on this and more from about year and a half ago
reall you are better off just getting an avswitcher (click on the link in my signature)
Old Mar 13, 2006 | 09:59 AM
qh187's Avatar
is there a way to get this screen without having PIE or SAT?
Or does anybody know how the TV is switched on in the JDM version?
Old Mar 13, 2006 | 03:09 PM
the tv tuner is a seperate box that converts the tv signal into another port on the back of the nav unit...so the software to control the tv tuner is in the nav unit and tied into the head unit but the video in capability and tuner is solely in the tuner which non-JDM cars do not have.
even if you got the TV tuner there would be problems...
1)lack of proper wiring harness
2) video in on the tv tuner is PAL
3) JDM broadcast frequencies differ from US broadcast frequences...in other words you'd never get a signal
Old Mar 13, 2006 | 03:42 PM
qh187's Avatar
i'm not looking for the tv tuner unit. I'm looking on how to get that screen to come up without going and purchasing the pie adaptor.
I believe I have found out how to input composite video without external hardware but I can't tell unless i can get that screen up. The TV tuner is for the Japanese market which uses NTSC so I shouldn't have much of a problem there using my video.
Old Mar 13, 2006 | 03:46 PM
your right about the NTSC thing...I got mixed up with the international dvd drive we hooked up
the pie unit is how the tv tuner plugs in so it activates a whole new external input...if turns off the head unit while on the ex1 of the PIE it will stay on
really if you want auxiliary input anyhow you might as well get the PIE...since your not going to want to put audio in using an FM modulator
Old Mar 13, 2006 | 04:05 PM
I think he is trying to follow up on the 'composite' pin in the wiring diagram
I must warn him someone else tried that and blew his nav unit's motherboard...fortunately he reassmbled everything and mazda replaced it under warranty haha
Old Mar 13, 2006 | 04:12 PM
qh187's Avatar
I will keep everyone posted but it'll be a while if I need to go the PIE route unless someone wants to donate a PIE adaptor or sell me one for cheap .
Old Mar 13, 2006 | 04:21 PM
KAtC10's Avatar
...goes like stink...
N00b question: What is PIE?
Old Mar 13, 2006 | 04:24 PM
http://www.mazdaparts.com/ProductDetail.jsp?LISTID=1E0000-1112606399
gives you an auxiliary input (must also purchase cable on same screen)
in other words a crystal clear audio input into the stereo (for hooking up mp3 players or dvd players or whatever)
Old Mar 13, 2006 | 05:31 PM
qh187's Avatar
The composite pin is actually for composite sync which is the sync signal in the RGBs that the DVD unit uses. The input I am going to use isn't listed in the wiring diagram as far as I know. It should be the same one that the TV tuner uses.
Old Mar 13, 2006 | 07:24 PM
I'm not referring to that composite pin...let me see if I can get the wiring diagram up, it has been over a year and a half since I was working on this so I'm a bit out of touch
I do have an extra Nav unit I can play with though
Old Mar 14, 2006 | 08:56 AM
qh187's Avatar
this isn't my screen but does anybody know what it says?
truemagellan if you can get the wiring diagram that you're referring to up that would be great. I want to be sure i'm heading in the right direction before i say anything.
Old Mar 14, 2006 | 10:46 AM
ask japan8 there are a few other guys too...I'll send it to my south korean friend he knows japanese but he is in the army there so his online time is irregular
Old Mar 14, 2006 | 10:54 AM
hmmm I have the back of the nav pinout but can't find it...for now here is the display pinout and one of the nav pinouts without legend
