suspension problems (rear tires not straight)
I was looking at the rear of my car today and the rear wheels dont look straight.they seem to go into the fender on the top . i change my coilovers and had the car aligned is this normal ???
Originally Posted by Mikelikes2drive
^yah wat he said... u can straighten it out by gettin a camber kit if you wish
Originally Posted by NoCones
You could, but if you care about handling at all you won't. Negative camber is not a bad thing folks. Static negative camber turns into a nice vertical tire with a nice flat contact patch when that wheel is loaded in a turn. And camber (at least the amount you can get with a stock 8) is not going to affect tire wear noticably...excessive toe will, but not a little negative camber.
:p
Originally Posted by clyde
Please be sure to max your negative camber in the rear by next Satruday.
:p
:p
I wonder what the max in the rear actually is?
I should have also mentioned above that negative camber on the drive wheels can hurt forward bite if you go too far...and how much you might want in one end could depend on what's available at the other end (the RX-8 is rather limited in the front). The kind of suspension you're dealing with matters too...some designs have different changes in camber over the range of travel than others.
I've got -1 degree (give or take a tenth) all the way around...what do you have in your car, Clyde?
Bryan
I've got -1 degree (give or take a tenth) all the way around...what do you have in your car, Clyde?[/QUOTE]
More than that all around.
:p Think I want to take some out of the rear, though...dunno. Haven't taken measurements in quite some time either...so I really don't know what we've been running so far this year.
xAgyex
Jun 3, 2026 03:47 PM
WingleBeast
22
May 23, 2016 09:22 PM
Solidtrance
22
Sep 4, 2015 12:47 PM
