View Full Version : need help
bt600rr
05-28-2005, 12:46 AM
I'm trying to attach some pics, file to large, whats the easiest way to reduce size. Any help would be appreciated.
Bonton
05-28-2005, 12:52 AM
do you have photoshop?
bt600rr
05-28-2005, 01:00 AM
yes I do
Bonton
05-28-2005, 01:15 AM
okay.
1. open doc. in P/S
2. in IMAGE menu highlight "image size"
3. you can resize the image by entering values into the width/height fields(check constrain proportions box)
use "save as" so you have your original.
you can also use the crop tool to cut off extranious pixels, open doc "save as" rename and crop.
hope this helps
\\Konig\\
05-28-2005, 03:07 AM
be sure to check the file size after you resize it to be certain that its under 100kb, which is the size limit of pics on this site (correct me if im wrong plz)
