DSC help...
Old May 27, 2005 | 10:31 PM
rx8relic's Avatar
Question DSC help...
I need some help with reseting my Traction Control, I removed my battery terminals to run wires for my amp now my dsc light is flashing at me nonstop.... does anyone know how to reset this?
Old May 27, 2005 | 11:29 PM
sco's Avatar
sco
Turn the car to on. Turn the wheel to the extreme left then to the extreme right. Switch to off, switch to on. The lights should go away.
Old Jun 11, 2005 | 10:40 AM
Phlash's Avatar
Go Speed Racer, Go!
Excellent post! Thank you!
Old Jun 11, 2005 | 10:45 AM
army_rx8's Avatar
X-Sapper
hehehehe after a while mine woudl just reset onit's own..i think 2 drive cycles (car is on and off 2 times)......this happened to me when i put on my water temp sensor had to remove the battery for that..it was out for about an hour.
never did try the turn the wheel thing..that woudl probable work fater than just waiting...as we all liek instant gratification.
Old Jun 11, 2005 | 11:08 AM
adrian-1's Avatar
Ex- member.
You could also find the reset procedure in the owner's manual. Under the DSC section.
Old Feb 11, 2008 | 02:08 PM
DOMINION's Avatar
I don't buy Kool-Aid
I disconnected the battery my DCS light will flash when I start the car and the traction light stays on. I'm going to work in a bit. I'm going to try turning the wheel all the way to the left and all the way to the right, switch to off, switch to on, to re-set it.
Serching is cool
OfficerFarva
Dec 5, 2015 10:53 AM
D13
Oct 1, 2015 07:55 AM
Stubbs
Sep 27, 2015 04:06 PM
Evan Gray
Sep 26, 2015 12:30 PM
