Hymee Exhaust installed
Old May 27, 2005 | 06:13 PM
Richard Paul's Avatar
Couldn't wait anymore, had to install it. I wanted to wait until after they fixed my car but there it sat and there the car was. Look to my left and there's the Hymee, to my right the car. Left, right, car, exhaust what to do? I'm weak, I put in.
This exhaust has just the right amount of sound, mild until you push hard past 6000, then it gets agressive. No drone, can't hear it at idle but does have a tune even off idle, just does not offend or sound ricey.
As for the unit itself I have to offer **** to Hymees welder whoever he may be. This guy must have laid down hundreds of miles of bead. The fab work is super and it is a damn shame you can only see the tips. You might want to park over mirrors so people can see it.
Back to the tips. great finishing touch, they fill the openings much better then the stock. The taper going into the tube looks neat. :D
I don't think it is a home install unless you have a tourch. On my car the factory had clamped the tubes so tight that they were crushed. There is no way you can get the new tube to go into the stock outlet. I just cut it off a little way past the damaged part and welded the new part to it. I used stainless rod. It is still a bolt on because of the flange you just can't go back to the stock unit without some more welding.
I don't think many will be wanting to go back to stock. Sorry I didn't weigh them both for you but I'm sure Hymee has. Also I know you would like me to have done a dyno before and after but the car is not running right anyhow.
I haven't done a long freeway drive yet but I'll let you know when I have, maybe tonight.
Old May 27, 2005 | 07:05 PM
dj.stains's Avatar
great wheres the pics
Old May 27, 2005 | 08:08 PM
sco's Avatar
sco
You can fit the exhaust to the standard pipe but it takes some work. Some sumo tightens that U bolt in Hiroshima I'm sure. It took a bit of torch work and much beating to get the pipe back to round before Len and Hymee could get mine on. Any good exhaust fitter should be able to do this.
Old May 27, 2005 | 08:32 PM
Why bother? If you have a torch weld it. Better joint anyway, no leaks, no parts to losen.
Old May 27, 2005 | 09:04 PM
sco's Avatar
sco
Why avoid welding... easier to go back to stock I suppose?
Old May 27, 2005 | 09:24 PM
xxup's Avatar
I have not fitted one yet, but I often wondered why it was not made a bit bigger and bolt on to one of the existing flanges???
Wouldn't this avoid the need for blow torches and welding???
The exhaust is now further delayed by the arrival of the Scanalyser and the need to buy a new notebook... Sigh!
Old May 28, 2005 | 03:32 AM
truemagellen's Avatar
Attracts tree branches
my Hymee was installed using a U-Lock with a spot weld on the 'L' lock for the old piping
really after the thing heats up and expands...it seals the pipe shut
as long as you do a good job of 'pumping out' the old pipe it will be more than fine...
as said before stock intermediary pipe will be deformed like u would not believe!
BTW LOVE LOVE LOVE the Hymee...exhaust AND sCANalyser that is :D :D :D
just been to dang busy to make my own review
here is a pic until richard posts some:
(this is a day after tips installed so it hasn't been burnt in thus I haven't cleaned them off...so now they are as bright and shiny as the rear rotary accent)
Old May 28, 2005 | 09:30 PM
Got flames!!!
Old Jun 1, 2005 | 11:22 PM
St.Char's Avatar
CarCrazy
You go Jason...I like the pic!
Old Jun 2, 2005 | 12:47 AM
dpm's Avatar
dpm
Danimal
Mines on its way. I cant wait
Old Jun 2, 2005 | 10:23 PM
LiL BenNy's Avatar
Bubblicious? DEF.
is it me or do those tips look like they come out too far?
Old Jun 2, 2005 | 10:28 PM
Gomez's Avatar
Shifty Bastard.
It's you....
Attached Thumbnails Hymee Exhaust installed-6000mile-hymee-003.jpg   Hymee Exhaust installed-6000mile-hymee-009.jpg
Old Jun 2, 2005 | 11:23 PM
^^^^What he said.
Old Jun 3, 2005 | 08:15 AM
smrx8's Avatar
i wonder how loud this exhaust would be with a high flow i been digging this exhaust for a while now
Old Jun 3, 2005 | 10:22 AM
canaryrx8's Avatar
Originally Posted by Richard Paul
Got flames!!!
hahaha too funny :D
Threshermal
Apr 15, 2020 09:43 PM
LMURailsplitter02
Sep 6, 2015 10:56 PM
Rupanrx
Sep 4, 2015 06:44 AM
yapakanichi
Aug 25, 2015 01:24 PM
