Radio Power Harness
Old May 24, 2005 | 12:55 AM
Rotary Rasp's Avatar
503wtq Boosted Bimmer
Radio Power Harness
I saw a thread some time back that showed the wire harness for the radio. I'm getting some bad alternator whine (only when the battery is low) and want to see if I can ground the radio to another location. I searched, but had no luck.
Thanks.
Old May 24, 2005 | 11:43 AM
bump.......!
Old May 24, 2005 | 01:01 PM
forbidden's Avatar
What have you used to interface to the factory head and what amplifiers are you using. Did you ground direct to the battery as I had indicated earlier?
Old May 24, 2005 | 02:17 PM
The radio is the stock bose system. I just want to know the pin out of the radio.
Old May 24, 2005 | 02:21 PM
forbidden's Avatar
I have the head unit out of one right now. I'm busy today (lunch time right now = time to post) but later on I'll see what I can find for you.
Old May 24, 2005 | 02:37 PM
thanks, mainly, I just need to know what color the power, ground, and ignition wires are.
Old May 24, 2005 | 02:44 PM
mazradiodoc's Avatar
looking at back of radio
Old Jun 1, 2005 | 07:59 PM
Do you know what color the (r) wire is?
Old Apr 20, 2019 | 10:40 PM
nbetcher's Avatar
Does someone have a working copy of this image?
Old Apr 21, 2019 | 08:57 AM
Loki's Avatar
It works, just have to download the attachment instead of simply viewing it.
Old Apr 21, 2019 | 01:52 PM
Tamas's Avatar
Registered Lunatic
Old images can be opened in a new window instead of viewing them.
Right-click and "open link in new window"
Old Apr 25, 2019 | 01:11 PM
nbetcher's Avatar
That's intuitive, lol. Could really have used that knowledge a lot over the past couple years... couldn't find a sticky about it before my ADD kicked in.
Thanks ya'll.
Adding some substance to this post:
(h) is a, "remote on" for a power antenna I believe (to power it to go up, and goes down when current is lost). [Don't believe a single RX-8 has a mounted antenna, let alone a power one.]
(j) is a, "remote on" for the factory Bose amp, if applicable to your vehicle's VIN. Note: see (1) below.
(n) is steering wheel controls #1 and the only wire you need for any RX-8 as far as I'm aware. (see (p))
(p) is steering wheel controls #2, but these are for call functions (accept call, hang up, issue voice command to infotainment center), so not available on RX-8s (at least S1s).
Notes:
(1) When Bose stereo deck is present the Bose amp is only provided 12v @ 20mA. Many pro-decks have an activation wire; I know Xtrons does for sure -- those activation wires should carry considerably less current, but regardless of the amount of current used anything should work.
shaun_wilder
Aug 24, 2012 12:16 PM
sauceyI986
Oct 12, 2011 10:58 AM
salejel
General Automotive
Aug 9, 2011 10:11 PM
jsgates
Sep 11, 2006 09:13 PM
jgoldstein2000
9
Aug 26, 2004 12:36 AM
