srmotorsports RX8_Clutch_Flywheel KITS.
Old May 22, 2005 | 01:48 PM
X-SIN-X's Avatar
At the link below you will find 2 different setups for Clutch and Flywheel setup. I am interested now in making this combo purchase. Has anyone on here installed either of these two? What are your impressions? Pros/cons? Realistic street drivability? Also, should I consider a different setup? I don't want to fool around with adjusting here and there just to get 2 different products to work. A smooth product buy, product install and mod done. Does this exist? Please provide useful comments. Thanks.....
http://www.srmotorsports.com/RX8_Clutch_Flywheels.html
2004 - 2005 Mazda RX-8
Complete Kit Includes all needed parts: #9.75 aluminum flywheel, modified counterweight, hardware and bearing kit, pilot bearing, pilot seal, throw out bearing, alignment tool and Heavy Duty clutch set. (race or street / strip)
***This performance clutch holds 50% more power than the stock unit which tends to slip ***
$849 Sale Thru FridayReg.$1137
Part Number RE-13120HD
***********************OR************************* *******
Complete Kit Includes all needed parts: #9.75 aluminum flywheel, modified counterweight, hardware and bearing kit, pilot bearing, pilot seal, throw out bearing, alignment tool and Extreme clutch set. (race or street / strip)
***This performance clutch holds 110% more power than the stock unit which tends to slip ***
$869 Sale Thru Friday Reg. $1197
Part Number RE-13120EXT
Old May 22, 2005 | 02:34 PM
I'm thinking the same thing.
Go with the first kit as you will be good for 350 plus RWHP.
The second kit is much stiffer and is for off road use only. Like drag or track only.
The first kit you can use for both applications.
Old May 22, 2005 | 03:37 PM
rotarygod's Avatar
I have that flywheel on my RX-7 and absolutely love it. It is the last flywheel I will ever buy. Just use the Heavy duty and not the extreme clutch. You have no need for the extreme cluth and probably never will. It is a full race puck clutch. The pedal effort is very stiff and the engagement is very abrupt. Your foot will get tired very quickly on the street and it will be fairly difficult to get the car moving at first. They are designed for very high horsepower cars. I seriously doubt anyone in the near future will have a need for one on an RX-8. There are only a few people running around with race pucks and those people are driving 400+ hp rotaries and typically not as daily drivers. Stick with the Heavy duty one. You'll be fine.
Old May 22, 2005 | 03:44 PM
X-SIN-X's Avatar
I appreciate the valuable info. I think I will purchase in a couple of days.
Old May 22, 2005 | 04:28 PM
Fanman's Avatar
I have the SR Motorsports flywheel on my car. It is a nice piece. You may also want to look at the Racing Beat Flywheel with ACT Clutch package that www.rx8store.net is offering. Less expensive, & just as good in my opinion.
Old May 22, 2005 | 04:41 PM
X-SIN-X's Avatar
ACT Clutch and RB Flywheel Combo runs 830 and the srmotorsports Heavy duty is 849. I think I like SR better for 19 dollars more.
speeddemon32
348
Sep 20, 2025 04:10 PM
smrx8
36
Jun 12, 2007 07:58 PM
cptmorgan2000
Nov 27, 2004 02:55 PM
Phoenix_Master
30
Jul 24, 2004 12:47 PM
