flywheel, balance, seals, bearings?
I'm going to change my flywheel. Ive read on the sr motorsports that they rebalance the counter weight. is this nessisary or are they crazy? RB, mazdaspeed, fidanza etc just use a std part so what is the issue?
next; what seals and bearings should be replaced? the throwout bearing but what other ones and which seals?
is there a need to reface the clutch disk?
The standard part will work. It's not necessarilly perfect. There is a tendency for Mazda to use heavier counterweights on the autos for some reason even if the rotors are the same weight; to eliminate resonances peculiar to these cars, who Knows? Someone trying to do it absolutely best as possible might cut it a bit. All of the companies you mentioned have pretty sharp people on staff even if opinions may vary slightly.
Paul.
Paul.
Tgiolitto100
Sep 29, 2015 10:52 AM
