Another audio thread :)
Old May 10, 2005 | 02:10 PM
akersjp's Avatar
Hello,
Today I decided to go to a local audio shop to have a talk with their install guy. I went in not knowing exactly what I wanted and told him I was up for suggestions. He looked at my trunk and explained it would be easy to make a box for a 12" sub. Here is what he quoted me and I wanted your guys opinions thoughs on this setup. To me it sounds like a LOT more than what I need. I really just want to improve the bass (I have the bose currently). Here are the components he showed me:
Eclipse 12" Alum Cone 900W 4 OHM DVC (SW7324DVP) - $187 (seemed reasonable)
Eclipse 490 4 Channel Amp (EA3422) - $208 (also seemed reasonable)
Install - $75 + $80 (custom box) - $155 (not bad since I don't want to mess up the installation myself and don't have the time)
What are thoughts opinions for just wanted to upgrade my bass? I don't need anything ridiculous, but I don't have anything to compare this against. Is a 12" too much for just wanted to improve bass? I know its probably everyone's own opinion, but this setup seems too much. Also does anything know any reviews on these items? I googled for a while, but couldn't find any reviews that really say anything much on the amp, the sub got good reviews, but again nothing definitive from a trustworthy source. Please let me know any thoughts, thanks.
akersjp
Old May 10, 2005 | 02:18 PM
Rotary Rasp's Avatar
503wtq Boosted Bimmer
First of all....12's do not fit easily fit in our trunk. given there is only about 13 inches to work with. Second, if you have the Bose system you'll ned to invest in a differential line converter. (i'm sure the guy didn't know that) Third, why are you buying a 4 channel amp for a sub? If your getting a 4 channel amp you'll need new speakers, plus another amp for your sub.
Old May 10, 2005 | 02:43 PM
canaryrx8's Avatar
I'd go with 2 10s instead of the 1 12, the 1 12 will be cramped a bit, but not impossible. As far as the 4 channel amp, there's nothing saying you can't go with that but I wouldn't unless you want some flexibility for future use. (like if you planned on swapping factory highs later or something) If you're just wanting something to drive the sub, a 2 channel with a nice built in crossover should be just fine A 4 channel is a bit of a waste.
Old May 10, 2005 | 02:47 PM
akersjp's Avatar
Rotary Rasp,
Thanks for the response, this is exactly the kind of thing I was trying to find out. The 12" didn't fit too bad in the trunk, he had 2 layouts, with it in the back of the trunk and with it laying flat facing up. I explained I had the bose system, but I don't think he really thought about it. How much is the differential line converter? I'm not buying anything yet, so the 4 channel amp is just something he showed me, thats why I posted what he showed me and wanted to know all your guys opinions.
Are you sure I would need new speakers and another amp for the sub? Can't they just use 2 channels? Anyways, I don't if this is what I need or not, just starting a conversation to help flush out details that I can go back and ask him about. So everyone here just have a 2 channel amp? Thanks again for the response, any help is great.
akersjp
Old May 10, 2005 | 02:50 PM
akersjp's Avatar
canaryrx8,
Just saw your reply, sorry I was in the middle of replying and you answered my question. I really think I just need to drive the sub and don't care about future use (although would it hurt, and like rotary rasp said would I have to get new speakers and another amp???). And are the eclipse pretty safe to go with? And where were you thinking to mount the 2 10's? He said if I wanted to do it on the sides of the trunk that would cost more for the custom fiberglass install....thats why he suggested just the box. Thanks again.
akersjp
Old May 10, 2005 | 03:03 PM
Tamas's Avatar
Registered Lunatic
If I were you, I'd just get a box for a 10" sub from 4080 and put a sub in there with a JL Audio amp. No need for a 4-channel amp for that - get a dedicated mono amp for the sub.
Old May 10, 2005 | 03:09 PM
afeldman327's Avatar
If all you want is bass, buy a mono amp, a 10" sub, and a box from 4080. of course you'll also need a line-out converter and have to tap into the rear speakers. This is exactly my setup! optimum setup.
Old May 10, 2005 | 03:10 PM
DreRX8's Avatar
Or you could go with one 8" or 10" sub if space is an issue. 12" is overkill for this car IMO --you don't want to drown out your highs.
Old May 10, 2005 | 03:17 PM
akersjp's Avatar
This is exactly the kind of discussion I wanted to start. Thank you everyone so far for the replies.
Ok sounds like the 12" is overkill. 2 replies said from get a 4080 sub, is there a link to this or a model # or a brand? I did a google for "4080 sub" and got varied results. Also sounds like a mono amp is all I'll need, what about a remote control for the amp so I don't have to a) cut into my car to get a control for it, and b) I can adjust volume to amp without getting into the trunk? I asked the guy at audiosmith about this and they said remotes aren't really done anymore, I figured that was crap, but wanted to know everyone's thoughts on that.
afeldman327 - Sounds like your setup is really simple...what do you do about controlling amp volume and if you had to tap into the rear speakers was that really easy to do?
Thanks everyone again, this is great info.
akersjp
Old May 10, 2005 | 03:31 PM
TRU681's Avatar
Just want to add, Eclispe subs are really good.They hit hard & clean.The aluminums are pretty good for that price. I have the Eclipse titanium series in my 8.
Old May 10, 2005 | 03:35 PM
Tamas's Avatar
Registered Lunatic
4080 is a username on this board - send him a PM and inquire about his sub enclosure.
As for a remote gain adjustment for the amp, that should be no problem - I've seen threads where people had such a gain control **** installed upfront, in the area of the coin tray or the center console. A decent audio shop should not have a problem with that.
Old May 10, 2005 | 03:40 PM
carls's Avatar
I'll throw in my $0.10. I went with a JL Audio 10" sub in a factory built enclosure, along with a JL Audio e1400D amp to drive it. Don't tap into the rear speaker lines for the signal. Tap into the pre-amp low level signals.
Here's the thread that shows what I did:
https://www.rx8club.com/series-i-interior-audio-electronics-24/jl-audio-subwoofer-install-48837/
Here's a thread about tapping into the pre-amp low level signals from the Bose amp:
https://www.rx8club.com/series-i-interior-audio-electronics-24/pre-amp-outputs-tapped-stock-bose-16214/
-Carl
Old May 10, 2005 | 03:41 PM
akersjp's Avatar
TRU681 - What size is the sub that you have from eclipse? Good to hear you like them, makes me feel easy about that brand.
Tamas - for the remote gain control, I'm thinking of a wireless remote....audiosmith said they would route a wired control to the front, but I would rather have wireless, any suggestions from anybody on this one?
Thanks again.
Old May 10, 2005 | 03:51 PM
Bose line converter: http://store.yahoo.com/logjam/sounlocbosli.html
I said you should get new speakers because you said you're getting a 4 channel amp, so I thought you were going to amp your highs. Don't get a 4 channel amp for a sub because you can not get them with Class D circuitry. Most 4 channel amps only come in A and AB which is not good for a sub amp unless you like having a stove in your trunk. If I were you i'd buy a Infinity Basslink and replace the rear 6x9's....it would cost you about 400 bucks for everything and you could install it yourself in no time.
Old May 10, 2005 | 04:07 PM
Tamas's Avatar
Registered Lunatic
Yeah, the Basslink is a good idea if installation simplicity is important.
Old May 10, 2005 | 04:10 PM
forbidden's Avatar
Close but no banana's guys. Don't get fooled by the effiecientcy of a class D amplifier, there is nothing wrong with a class AB, matter of fact that was what was used for years before Class D was even available. What the original post needs is this.
1) a way to control the sub
2) a way to integrate it into the factory system
3) the option for expansion in the future
4) a decision on what type of output levels he is expecting
- annoy the neighbourhood
- round out the sound
5) a proper match of components
Follow these rules
1) good bass response is all about the box.
2) good bass response is about being able to control it.
3) good bass response is about matching equipment together properly.
4) a happy customer is one that knows how to use the system properly.
- the person does not expect too much from something too small
- the person does not keep the system pinned at full output.
Go to this site and read my grounding sticky, it is a must in this vehicle, even for a basic sub system. It is in the car audio forum. www.the12volt.com
What you need is simple.
1) a good interface module
- Audio Control LC6 in this case
- takes the factory preamp line and converts it to a signal for your amp to run.
- add the additional bass remote for control of the sub indipendent of the main volume.
2) a box designed around the sub chosen.
3) an amp that will work with the chosen sub properly.
Advice is free anytime, I am swamped here at the shop right now and I have been working some totally crazy hours. I am on the PST time frame
Old May 10, 2005 | 04:12 PM
TRU681's Avatar
Thanks again.
I started with 1-12 inch Eclipse titanium Sw9122(750watts rms/1500peak).It was a tight fit to get the enclosure in.Now I have 2-12inch Eclipse titaniums now, one on each side of the trunk angled towards the rear 6x9's hole.
Old May 10, 2005 | 04:22 PM
forbidden's Avatar
No doubt that is a tight fit, what beast are you using to power those monsters. The Expedition that I have had here for 3 weeks has these subs in it.
Old May 10, 2005 | 04:30 PM
TRU681's Avatar
I have a Phoenix Gold Titanium 1000.2 triple darlington circuitry(the last line of US built quality for Phoenix Gold), a very flexible amp.It is also very underated in output.I'm into SQ so the 1000rms is plenty for my liking.
250x2 at 4ohms CEA rated
500x2 at 2ohms CEA rated
1000x1 at 4ohms bridged(birth sheet tested at almost 1200watts rms). CEA rated
Old May 10, 2005 | 04:33 PM
Class AB produce a better sound however they will get hotter. Class AB amps have better THD however, that's not important for subs because you can't hear the distortion anyways. Class AB amps are more likely to cause dimming of the head lights. This isn't my opinion, these are facts.
TRU681's Avatar
Follow these rules
Great post & I totally agree.That's why I have a class A/B amp to power my subs.Though it has more current draw & sound quality is better than Class D monoblocks.The enclosure is the biggest factor on how the sub will sound.
Old May 10, 2005 | 04:56 PM
forbidden's Avatar
The new generation of class D amps have a much more advanced internal circuitry and their sound quality has drastically improved. A shining example of this is the Xtant 1.1 amplifier. Now what most people don't understand about subs is damping factor. This is the amps ability to control the motion of the driver. As impedence drops, so does the amps damping factor. A sub amp driven at 4 ohms has far better control of a sub than a amp driven at 1 ohm, by a longshot actually. Current draw on the two amps is also close to the same. Yes the Class AB will run hotter, but it is also designed to get hot. Heat is a natural byproduct of amplification. How a system is wired and fired is at the discretion of both the installer and the salesperson, sadly there are many of these people that just do not do things correctly.
Old May 10, 2005 | 05:02 PM
akersjp's Avatar
Want to bring up a question I had earlier, what about a sub that is remote (wireless) controlled? Thanks in advance....
Old May 10, 2005 | 05:06 PM
akersjp's Avatar
When i said sub, I meant gain control for amp...sorry.
Old May 10, 2005 | 05:07 PM
akersjp's Avatar
Also, I sent a PM to 4080, but I haven't heard anything about the sub box enclosures for about 2-3 months. I read through all the threads and seems like the whole thing kind of died down. Anybody know off hand if he is still making them (I did pm him, but just curious...), or if anybody has one that they want to sell? Thanks.
