Driver's side rear too low
Old May 10, 2005 | 12:27 PM
RXATE's Avatar
Question Driver's side rear too low
When I first got the 8 I asked the dealer why the driver's side rear was lower than the passenger rear. I was told that they could find no problem and other 8's they looked at were similar. Now, 18 months later I notice that the problem looks more pronounced. The difference between the sides may be a couple of inches.
Has anyone experienced this?
Old May 10, 2005 | 12:50 PM
make sure you are on a level surface and using a tape measure determine the distance from the ground up to the center fender lip and compare sides
Old May 10, 2005 | 01:13 PM
JonsToy's Avatar
Registered Rep
Mine looks dead level, though I've never measured it. Sounds like a problem with the suspension, tire pressure, or both.
Old May 10, 2005 | 01:16 PM
army_rx8's Avatar
X-Sapper
yea i've never even heard of someone else having this problem (i dont' have it either)....take some measurements...i ftire pressure is okay (tpms is not on) then it's got to be your suspension is having issues.
Old May 10, 2005 | 01:25 PM
derwankel's Avatar
It is slightly off to compensate for the right hand drive Japanese driver ... Once he or she gets in it balances out. Ripley's ... believe it or not.
Old May 10, 2005 | 01:56 PM
TooBIG's Avatar
This is very common. You can search and find many threads.
Someone went to a dealer and found most of the cars on the lot were the same way.
BigMikeATL
May 26, 2016 12:31 AM
vapor2
Oct 8, 2015 02:08 PM
SayDfuse
Aug 3, 2015 10:41 PM
amshaw
Jul 27, 2015 08:41 PM
