Idle vibration and only 1800 miles???
Old May 9, 2005 | 08:26 AM
getoutdaway's Avatar
I have an '05 6 speed, with only 1800 miles on it, and once my RPM's go below 1000 at idle, I get a vibration, shimmy in the seat and gearstick. I see a previous post where someone said its a crack motor mount, but said that notice was for 18K-25K miles.
Mine is a minor vibration, maybe three vibrations every 15 seconds. The music and A/C must be off to HEAR them , but they can be felt with both on.
I called mazda, described it to service tech and he said "sounds normal for a car like that, do you check your oil after every 3-4 fill ups?" I told him I hadn't been. So I went and had the oil checked and changed. It still vibrates.
HELP!!!???
Old May 9, 2005 | 08:37 AM
Go48's Avatar
HELP!!!???
Sounds normal to me. Don't worry about it.
Old May 9, 2005 | 08:55 AM
Tigerfootball's Avatar
Clemson, NOT Auburn
i got a little over 24k and mine vibrates at idle sometimes. my only problem is that the airbag cover on the steering wheel rattles with it as well as some panel behind me that sounds like something is knocking inside it. i am going to the dealership later today for mine though.
but like Go48 said, i wouldn't worry about unless it gets too bad.
Old May 9, 2005 | 09:03 AM
my main concern to be honest is it stalling out at a red light...when the RPM's get down to like 750, its got that ba....ba....ba (low on gas hummm) if ya know what i mean....
when i stop my rpm stick gradually comes down to 1000 which is fine, then once goes below is where trouble start. WHAT IS PROPER IDLE RPM FOR AN '05 6 SPEED BY THE WAY?? 1000?? 750 SEEMS WHERE PROBLEMS START??
Old May 9, 2005 | 09:09 AM
khtm's Avatar
I like rusty spoons
When you're idling it's normal for your RPMs to alternate between 750-1000.
DON'T WORRY!
Old May 9, 2005 | 09:10 AM
khtm's Avatar
I like rusty spoons
Ahhh...here you go...read this thread:
https://www.rx8club.com/series-i-tech-garage-22/why-does-renesis-lope-idle-28678/
Old May 10, 2005 | 12:21 AM
Gear shift shake is normal. Any low idle below 1000 is subject oscilation
ironj221
36
Jan 20, 2026 08:28 PM
PotatoCannon
Sep 6, 2015 11:48 AM
Nisaja
51
Sep 1, 2015 04:29 AM
GrAfiX
Aug 24, 2015 08:08 AM
dbarber
Jul 25, 2015 01:34 PM
