Its too hot inside
Old May 3, 2005 | 05:48 PM
peralwhite8's Avatar
Its too hot inside
Why is my RX8 so hot inside the front side area?? there is hot air coming out of the vent even tho its down to the coldest zone... just feels really hot inside the car even at evening time. anyone having same issue?? but AC is working find...
This is even when car is not running just feels so damn warm!!
Old May 3, 2005 | 05:52 PM
Im_DANomite's Avatar
I love GOOOLD
well...these engines get really hot and the car doesn't insulate heat very well. i notice that my car, with the car running and ac blasted, the footwell still gets fairly warm.
on a side note. anyone ever notice when you come around a turn fairly quick, the heater starts to blow cold??? i guess the coolant in the heater core is shifting around inside.
Old May 3, 2005 | 05:54 PM
tiggerlee's Avatar
May Cause Anal Leakage
The rotary engine does produce alot of heat. As far as the A/C, if it's blowing hot air when on the coldest setting then take it back to the dealer.
Or maybe check out this DIY for colder A/C
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-easy-mod-colder-ac-42322/
Old May 3, 2005 | 05:59 PM
A/C is working fine....I guess it is normal with this Rotary Engine running hot!
Old May 3, 2005 | 06:06 PM
tiggerlee's Avatar
Try the DIY I posted. If you use your A/C alot then that simple and cheap mod may help. :D
theblinkof
Oct 4, 2023 05:24 PM
Quiggs321
Sep 30, 2015 05:34 PM
He||hammer
Sep 29, 2015 09:40 PM
